2.48.16 limits max autosteer speed to speed limit on local roads?
Discussion in 'Model S: Driving Dynamics' started by Vineeth, Dec 10, 2016.
  1. Vineeth
    Vineeth Member
    Seattle, WA
    Has anyone else noticed that it now seems to want to autosteer only at the speed limit and not 5 over on local roads?
  2. Gwgan
    Gwgan Almost a wagon
    Maine
    Did the update reset your preference for speed over limit? I really hope this isn't true.
  3. CmdrThor
    CmdrThor Active Member
    Marietta, GA
    To me it wouldn't really matter. +5 makes autosteer pretty much useless to me and I turn off autopilot when the speed is restricted.
  4. sdorn
    sdorn Director of Awesome
    Georgia
    I'm interested to know what you mean by that? Is Autosteer only sometimes speed limited and sometimes not speed limited? Under what situation would it be limited? Why is it useless in those situations (just because you end up going to slow?)?
    I don't have my car yet so interested in understanding.
  5. number12
    number12 Active Member
    Tesla
    He wants to speed.
    I just hit the gas during auto steer
  6. MP3Mike
    MP3Mike Active Member
    Oregon
    But with the newer versions that greatly increases the hold the wheel nags...
  7. sdorn
    Georgia
    Is autosteer always limited to 5+ over the limit? That would make it basically useless around Atlanta where all the speed limits are 55 but people drive 75 in the slow lanes. A group of Georgia State college students did an experiment/protest once where they got enough cars to fill all the lanes on the bypass around Atlanta and drove exactly the speed limit. The people stuck behind them lost their minds. It was crazy. Video below.
  8. number12
    Tesla
    Not if you have something tied to the wheel... jk drive with your knee jk don't update software jk constantly look at your dash instead of the road in case you miss a nag because that is safer than concentrating on the road.
  9. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    If the car thinks that it is on a restricted (non-interstate) road then yes, you are limited to +5 over the last speed limit sign the camera sees. This is a known issue for the many times the car is wrong about its position. TACC is not restricted. This restriction was introduced with FW 7.1.
  10. Nosken
    Nosken Member
    Lincoln, CA
    I have been testing the auto steer "nags". If after 10 seconds or more, of engaging auto steer, you put your foot on the accelerator, at all, it will give you the nag screen immediately. This is not to say, that you're pressing the accelerator for 10 seconds, it just means that after you've engaged auto steer, if you press the accelerator, right after engaging, nothing will happen, until it's been engaged for 10 seconds. After that, anytime you press the accelerator pedal you will get the nag. This might be OK for stop and go traffic, but it is terrible when you're trying to maintain traffic flow.
    My only trick to resolve this, is to just keep slight "turning" pressure on the wheel. That will resolve any nagging.
  11. davidc18
    Ft. Lauderdale
    you have no control over the +5 speed restriction on secondary roads. You only have control over the speed limit alert notification, which has nothing to do with autopilot.
    The +5 speed restriction was introduced with FW 7.1
  12. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    This thread is not talking about the +5 speed restriction, rather the newly introduced +0 restriction with the latest software update.
  13. Gwgan
    Maine
    Now you all are confusing me. I do not have the latest point updates. With lane-keeping active the car is restricted to +5mph over the known speed limit on secondary roads. I understood OP to say that now the restriction is at the speed limit. If so, I'll pretty much stop using AP altogether.
  14. NSX1992
    NSX1992 Member
    Thousand Oaks,CA
    Yes the new version limits your AP to the speed limit on undivided roads. This is probably getting us ready for self driving cars which will not exceed the speed limit or the driverless cars could get a speeding ticket. Bummer.
    • Informative x 2
  15. CmdrThor
    Marietta, GA
    A few others have answered that Autopilot is speed restricted on non-divided roads. The OP says in the latest update that limit changed from +5 to +0. For me even the +5 is too low as on a speed limit 35 road people are traveling anywhere from 40-50 mph. So I just don't use Autopilot in these situations.
  16. sdorn
    Georgia
    Thanks for the clarification. I thought autosteer was only for use on highways and limited access roads per the user manual, so I'm surprised it lets you use it at all on surface streets if it knows you are on a surface street.
  17. CmdrThor
    Marietta, GA
    It can be useful on surface streets, especially in heavy traffic. You just need to definitely keep your hands on the wheel, especially through intersections. When there are no lines it just follows the vehicle in front of you which might not be the best. But when traffic is moving 10 over the speed limit, it's time to turn off autopilot.
  18. u00mem9
    u00mem9 Member
    Latest update limits the autopilot speed on 2 lane roads to the speed limit?
    Am I understanding that correctly?
    It seems like the forum members would be loving their minds right now if that is correct. The car designed for California ...but misunderstands the roadway system in the rest of the country?
  19. sdorn
    Georgia
    As someone else mentioned above, I think this is just getting everyone used to the fact that autonomous cars will not be able to intentionally break traffic laws (including speed limits).
  20. u00mem9
    u00mem9 Member
    Is that acceptable to you?
