2.5mm Audio Input
Discussion in 'Model S: User Interface' started by mgdurand, Sep 28, 2014.
  1. mgdurand
    mgdurand Member
    Glendale, AZ
    So don't laugh - but my entire classical CD collection in on an ipod classic which does not have bluetooth. The device is not recognized when plugging into the USB of the car. The files are in Apple lossless and I don't want to re-rip every darn thing to FLAC, it's a huge box of discs.
    Sure, I love listening to Slacker's Trap and Hip Hop stations just to shake bugs off the mirrors (and convince my neighbors I'm a dope dealer - true story), but sometimes I'm in a more subtle mood. Has anyone added a 2.5mm input to the MS audio system?
  2. bollar
    bollar Disgruntled Member
    Southlake, TX
    I guess the good news is that the car also supports ALAC. You could just copy your library to a USB drive and play it that way.
    Most of my library is ALAC, so I can confirm it works fine.
  3. mgdurand
    mgdurand Member
    Glendale, AZ
    No kidding?! I tried that when I first got the car (3/14), maybe the ability is new? Gonna go try again, thanks.
  4. Rockster
    Rockster Active Member
    McKinney, TX
    Really?! I didn't know that the car played ALAC. I remember trying that a while back and thought it didn't work. I'll have to check again.
    If it turns out you need to stay with FLAC, you don't have to rerip the CDs. You can just batch process the apple lossless files to produce a FLAC version of each. On a mac, you can use Max to batch process ALAC to FLAC.
  5. bollar
    Southlake, TX
    Hm. You guys are making me question myself.
    I looked at a couple of files and their actually lossless AIFF encoded. Let me make an ALAC and see what happens.
  6. bollar
    Southlake, TX
    #6 bollar, Sep 28, 2014
  7. rcc
    rcc Model S 85KW, VIN #2236
    San Jose, CA
    I keep waiting for Tesla to support ALAC and shuffle play.
    Until then, get something like mediamonkey that understands ALAC format and will convert to FLAC. Rip whatever you want and copy the results to a USB thumb drive.
  8. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Just saw your new post. Hope they support this at some point.
  9. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    I use an iPod Classic and simply use an FM transmitter. Why not use that? You can also get a Bluetooth adapter for it, apparently. I found that out months ago in another thread here, but since I already owned the FM transmitter, I decided not to get the Bluetooth adapter. (Plus I'm not sure how well that would work...would it support shuffle, playlists, etc.) So I recommend an FM transmitter. Mine plugs into the 12v outlet (a.k.a. "cigarette lighter outlet"); a bonus is that the one I have charges as it plays.
  10. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    An FM transmitter would ruin the audio quality that these owners are striving to maintain using these compression algorithms. It would also waste the quality of the premium audio system. That said, it's a cheap and easy solution.
  11. mgdurand
    mgdurand Member
    Glendale, AZ
    Both of those are reasons I don't use the signal converters.
    Looks like I'll be converting file formats at some point; thanks for the links to those utilities.
  12. kendallpb
    MD, USA
    Steve: Somehow I figured people converted to good formats not due to the perfect quality of...car audio, of all things. Plus, the OP didn't say anything (till after your post) about striving for audio perfection--just that he/she wanted to avoid reconverting (nor having the premium system...not sure that would've affected my suggestions, anyway). Plus, I did mention Bluetooth, which is not FM. I thought it was better (is it not digital transmission of audio? I guess not? no idea), but I have no idea how it compares. But then, I'm not an audiophile, obviously. . . . ;-)
    mgdurand: Good luck to you! :)
  13. Gabzqc
    Gabzqc Member
    Finland, Helsinki
    Sorry to be utterly pedantic but I think you mean 3.5mm rather than the super tiny 2.5mm used in some older mobile handsets?
    Best of luck getting your collection to play!
  14. pete8314
    pete8314 Vendor
    DFW, ex UK
    Just for the record, I've tried various USB -> 3.5mm audio adaptors (mostly freebies with other stuff I'm buying from China), and none of them have worked in the Model S, unfortunately (and unsurprisingly, but you never know!).
  15. bsd
    bsd Member
    Guelph, Canada
    FWIW, we have a similar gadget and my experience is that it doesn't work well in areas with many FM stations if your FM antenna is at the back of the car.
