2 perfect CPOs which one do you pick?
Discussion in 'Model S: Ordering, Production, Delivery' started by Cooksomerice, Oct 19, 2016.
  1. Cooksomerice
    Cooksomerice Member
    Louisiana
    2014 S 85 kw 20K miles
    2014 S 60 kw 4K miles
    Same color, same finishes and options and very close in price.
    Which do you care more about?
    Low mileage
    OR
    Larger battery
    Which do you choose and why?
  2. andrerodpt
    andrerodpt Member
    Lisbon, Portugal
    Well.. 20K miles is hardly a lot. It only seems high mileage if you compare with the 4K one.
    And for me, the 85 would be the sweet spot. It would allow me to travel almost 100% of my annual drives without stopping.
  3. MrRandyB
    MrRandyB Member
    Delaware
    My opinion would be to go with the larger battery.
    I wouldn't worry about the mileage as much as you will be getting the CPO warranty on both cars, which is 4 years or 50,000 miles.
  4. No2DinosaurFuel
    No2DinosaurFuel Active Member
    San Diego, California
    85 for sure. The 2014 is the old S60 and IMO a very undesirable car once it ages. If you plan to keep you car forever and never to sell it and travel mostly in the city, then the 60 might be better at 4K miles because there might be less wear.
    But for everything else, the S85 will beat it.
    More range
    faster supercharging
    slightly faster to 60mph, albeit probably imperceptible.
    Keep in mind, the old 60 doesn't have unlimited battery and powertrain warranty. Unless I read the warranty agreement incorrectly for the CPOs, I think you only get the remaining of the original battery and powertrain warranty.
    The original S60 got only 8 years, 125K miles if I remember correctly.
    So if you do travel a lot the next 5/6 years and will be going over 125K miles, I recommend the S85 for unlimited miles warranty on the battery and powertrain.
  5. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Larger battery all the way. You will get faster charging and other benefits over the classic 60kW I believe.
  6. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Bigger battery.
  7. ww73
    ww73 Member
    Sammamish, WA
  8. brantse
    brantse Member
    Somerset, PA
    +1 for the 85, and this is coming from someone with a 2013 60.
