I noticed that the 256GB flash drive (Samsung, USB 3, exFAT, 30GB full) with music connected via a hub in the glove box takes a long time to mount each time the car starts up. The USB source is not immediately available. Is this normal?
Also, model year 2023 (Austin-built) has the mini-USB data cable taped up in the center console. I know there are aftermarket options to restore the data functionality. Question is whether this cable is connected on the other side (under the glove box). If it is not connected, is it in the area and easy to locate so I can connect it?
Thanks.
Thanks.
