2.X battery capacity
Discussion in 'Roadster 2008-2012' started by HHelge, Dec 7, 2020.
  1. HHelge
    HHelge Member
    Oslo Norway
    I bought a Roadster Sport 2012 from Tesla in Norway early 2013.We also signed a "Roadster Battery Replacement Program Agreement" at the time. After years of discussions with Tesla here I have just had the battery replaced. I have been told that the n
    Ew battery is a 2.X battery with specification somewhere between 2.5 and 3.0. The technician who did the replacement would not/was not allowed to say more than that. Do anyone have any more info on a 2.X battery?
    • Informative x 3
  2. jfischer
    jfischer Member
    Houston
    I got a REFURB battery in Nov of 2018. It wasn't a "NEW" battery and the range is nowhere NEAR a new 2.0 or 3.0 battery.... The CAC started at 159 which is a new 2.0 battery pack... but dropped to 135 within a few months....
    You mileage may very... just my experience on battery replacement... At least they HAD a battery and was able to replace my damaged one I'm still holding at about 135ish CAC two years into the replacement.
    Look on the part number of your battery and see if it says REFURBISHED / REMANUFACTURED
  3. Logticom
    Logticom 2010 Roadster Sport | 2015 Model S 85D
    Zwolle The Netherlands
    What's your CAC and ideal range on a standard charge?
  4. ViperDoc
    ViperDoc Roadster 1305
    Vermont
    I have a replacement contract from my purchase in 2011. It requires execution any time out to 10 years. I recently had to invoke it. Tesla told me that they are currently building new 2.x batteries at a rate of about 6 per month. Hand-built and new components, not remanufactured/refurb. They will have at least the capacity of the original. They also said they are still working on the second version of the 3.0 battery. No timeline on competing development since they admit they expected to have it a year ago. They told me that there is a chance that if they come out with 3.0, they might stop the 2.x manufacturing, and if so, we'd get a 3.0 for the replacement. However, they won't let me choose which battery I want right now. My only option would be to wait until the 10 year mark (last time I can execute contract) and execute it then to get me closer to the 3.0 production (if it ever comes to completion). However, since my car is currently not chargeable/usable, I sort of have to throw down on it now. Still, given the limited production, they told me that I am going to have to wait 8-12 months for mine to be manufactured...
    • Informative x 4
  5. jfischer
    jfischer Member
    Houston
    My CAC is 133.9 and Ideal Range on standard shows 165 Miles
  6. HHelge
    HHelge Member
    Oslo Norway
    Thank you
    The old battery was still OK. The reason for invoking the battery replacement agree was that I intend to sell the car in the spring and wanted to ensure it had a new battery with the associated guarantee already install in time. Enclosed is a photo of the label on the new battery. I also have a 30amp original Tesla charger which we have never used. Do you know if there exist an adaptor to enable the car to be charged from a Tesla charging station?
  7. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    This sounds suspicious. First I have never heard of a 1.5, 2.0 or 2.5 battery as the EES I believe is the same across all Roadsters. There are a few 3.0 packs out there but Tesla only made them for about a year and then stopped. So you likely got a refurbished battery if your CAC is less than 180 or possibly a 3.0 if your CAC is above 210. I saw your second post and you likely just received a refurbished standard battery. As for an adapter I used the Henry Sharp CAN SR but not sure if you have the same plug in the the EU.
  8. shrink
    shrink Supporting Member
    Phoenix, AZ
    If the 3.0 battery is still going to cost about $30K, can you hold off on your contracted battery replacement to the 10-year mark, hope to get a 3.0 and maybe just get a cheap lease on a Bolt in the meantime? Would just like you to maximize the potential value of your prepaid replacement if possible.
  9. HHelge
    HHelge Member
    Oslo Norway
    The battery has just been replaced a week and a half ago.
  10. slcasner
    slcasner Active Member
    Sunnyvale, CA
    Just to be clear, if you are referring to the Tesla Supercharger stations, then the answer is no, it is not possible for anyone to make an adapter so that the Roadster can use them because they require authorization using strong cryptographic methods. Tesla could make such an adapter (one ex-employee prototyped doing this), but Tesla does not want it to be done. However, as @dhrivnak mentioned, @hcsharp's CAN SR adapter allows us in the US to use Tesla Destination Chargers at hotels, for example.
  11. einhalv
    einhalv Member
    Horten, Norway
    The label on the battery of my 2.5S reads "ASY, ESS 2.0 -REMANUFACTURED". It was delivered by Tesla to the previous owner in the spring of 2019 after the original battery was bricked during storage. The version numbering of the batteries appears not to follow the version numbering of the cars and, based on what you say, perhaps this numbering is something they started doing recently?
  12. hcsharp
    hcsharp Active Member
    Vermont
    I've been building a CAN EU adapter to enable drivers in Europe, Australia, and HK to charge their Roadsters from common Type 2 charging stations using one phase. Although most of those stations are 3-phase, the Roadster can only charge from single phase.
    What @slcasner said above is true about supercharging. The Roadster can only charge from AC sources regardless of whether the adapter "fits". The only exception would be if you have an aftermarket CHAdeMO kit installed.
  13. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Can you tap a few times (6 to 10) on any unused area of the touchscreen in the car. It will ask for a code, so enter 1050. Then go to the ESS screen and send us a screenshot? That will tell us what battery they gave you, and what its health looks like.
  14. gregd
    gregd Active Member
    CM98
    The 1.5 and 2.x ESS share a lot, but I don't believe they are interchangeable. The 12v system, which starts inside the ESS for example, is quite different.
  15. HHelge
    HHelge Member
    Oslo Norway
    As you can see, the battery label clearly says Roadster 2.X
  16. HHelge
    HHelge Member
    Oslo Norway
    Hsharp, do you still have the EU compatible can for type2 charging available? If so, what is the price?
  17. HHelge
    HHelge Member
    Oslo Norway
    Enclosed please find screens hots as asked for.
  18. HHelge
    HHelge Member
    Oslo Norway
    Screensjot1
  19. HHelge
    HHelge Member
    Oslo Norway
    Screenshot2
  20. dhrivnak
    NE Tennessee
    OK you have the base battery and I stand corrected as there is likely a difference between the 1.5 battery and the 2.x as the 1.5 also supplies 12V power. But same cells and capacity.
