Nope. December 2020 install and part of a VPP here.Have most people's Powerwalls updated to the newest version. Mine are still on 20.49.0
In the installer menu when installing and commissioning Powerwalls there is a update firmware option. Maybe your third-party didn’t run that when installing? Maybe you could ask them to come back and do it? Pretty much the only change was improved local security making it harder for someone to access the UI over the network if they also had physical access to the Powerwall.I'm still on 20.40.3. My system was installed via 3rd party mid March 2021.
I assumed that it would update on its own. I have 2 PW which covers my peak starting load. I'll leave it as is and see if it eventually gets it. But as of now, it does what I want it to do.In the installer menu when installing and commissioning Powerwalls there is a update firmware option. Maybe your third-party didn’t run that when installing? Maybe you could ask them to come back and do it? Pretty much the only change was improved local security making it harder for someone to access the UI over the network if they also had physical access to the Powerwall.
I have seen it there but talking to tesla PW folks, got the impression they would push one if needed.In the installer menu when installing and commissioning Powerwalls there is a update firmware option. Maybe your third-party didn’t run that when installing? Maybe you could ask them to come back and do it? Pretty much the only change was improved local security making it harder for someone to access the UI over the network if they also had physical access to the Powerwall.
I'm also on 20.40.3. Funny thing is that the installer wizard says my firmware is up to date, even after I click a button to check for the latest version, even though I'm a couple versions behind.In the installer menu when installing and commissioning Powerwalls there is a update firmware option. Maybe your third-party didn’t run that when installing? Maybe you could ask them to come back and do it? Pretty much the only change was improved local security making it harder for someone to access the UI over the network if they also had physical access to the Powerwall.
Same here, but I've been running my system in backup mode until I get PTO. Maybe the fact that the system sees the grid as "down" that it won't take an update?I'm still on 20.40.3. My system was installed via 3rd party mid March 2021.
You are on 20.49.0, the second latest. The others are on 20.40.3, the third latest. Note the second number between the decimals is smaller in the one ending in .3 so it is older.What is the “.3” that most have? I’m still “.0”
Thanks. Didn’t notice the middle digit difference.You are on 20.49.0, the second latest. The others are on 20.40.3, the third latest. Note the second number between the decimals is smaller in the one ending in .3 so it is older.
Tesla’s format changed end of 2020 so that the firmware version number is represented by the two-digit year (20), decimal point separator, week number of the build (49), decimal point separator, then version of the build presumably starting at zero and going up.
