Hi Folks,
New to this forum, but I thought I'd join and post this because I don't see much information related to the fitment of the 20 inch Uberturbine wheels on the Model Y LR AWD.
1) Wheels:
The M3P uberturbine wheels have a square fitment with all wheels 20x9, ET34. These were taken from the Model 3 Performance and put on my MY! NOTE: THESE ARE NOT THE 21" MODEL Y STAGGERED UBERTURBINE'S.
I had the 19" Gemini wheels before this and was debating whether I should add the $2000 induction wheel option from the factory. Honestly, I love the look and color of these uberturbine's even more than the 20" inductions.
See below picture of my MY LR AWD. This should also fit the MYP.
2)Tires:
Note: This 9" wheel would have also perfectly fit the 255/40R20 which come with the induction tires. 245 or 255 wide tires are designed for 9" wheels.
However, I opted to go for the Michelin CrossClimate 2 in 245/45R20. Note: The thicker sidewall impacts the circumference of the tire slightly, so when the speedo reads 60 mph, I'm actually going 61.4 mph. Its something I have to keep in mind but its ~2% so its not a big deal for me.
I also decided to stick with the thicker sidewall because its SIGNIFICANTLY more comfortable to me. Honestly, this feels quieter and more comfortable than my 19" Gemini wheels with the continental tires -Perhaps its because the CrossClimate2's are a better tire? I'll update how my range is impacted after a thousand miles or so. Zero rubbing or clearance issues at full wheel lock and over large bumps on stock suspension.
Here's how the stock Gemini's compare with the new tire and rim combo: Rim & Tire Size Calculator. Custom Offsets
3) Offset:
I really like the stance of these new rims. It sticks out about 8mm more and looks flush with the fender. So much nicer.
"Wheel fills out the wheel well by extra 8 mm. Acceptable for most cars"
"The tire will stick out 6 mm farther. Rim will stick out 5 mm farther. Acceptable for most cars"
4) Alignment
This is a minor increase in height - about 4mm (0.15inch). I don't think I need to re-do my alignment but someone chime in if I'm mistaken.
Summary or TLDR:
I think the M3P 20" Uberturbine wheel is an excellent alternative to the 20" induction wheel for the Model Y.
Now I have my Gemini wheels sitting in my garage - up for sale if there's interest (dm me) or I might get it powdered coated in black and re-sell.
Hope this helps out someone!
1) Wheels:
2)Tires:
3) Offset:
4) Alignment
Summary or TLDR:
