20" Model 3 Performance Wheels/Tires/TPMS $2000
Replaced my 20s with some 18s. No longer need these.
One has been bent and repaired. It leaks from the bead on the inner side. The leak slowed after it was straightened but is still there. Maybe the tire is damaged? The shop didnt mention it if it was. I have included pictures of the repaired area, the two leaks with some soap, and where I marked the tire in blue where the leak is.
The other 3 I had no issues with.
They have between 6/32 and 8/32 tread left.
They come ready to mount, aside from the leaking one. TPMS are included. I will even throw in the stock lug nuts if desired.
Asking $2000 picked up in the Napa, Ca area preferred. I priced slightly lower than what ive seen them go for due to the one wheel having been straightened and leaking air.
Updating this listing.
I have since taken the wheel back to the tire shop. They remounted the tire and cleaned up the repaired area. The tire no longer leaks and the repaired area looks much better.
I cleaned them up and took new pictures that I have posted in this reply. While cleaning them I found the repaired wheel to have some scratching on the face. It looks like the wheel was stored face down at some point. Not sure where this happened but it did. There is also a mark that looks like curb rash but being that I have never hit a curb I assume it was done while the tire was being removed and reinstalled.
I can meet in Napa, Ca or Fremont, Ca. I travel to and from for work and take 680 so can probably meet anywhere along that path also.
