20" Winter wheel setup; tires thanks to Doc @ TireRack
Discussion in 'Model S: Interior & Exterior' started by Luder94, Dec 12, 2013.
  1. Luder94
    Luder94 Member
    Algonquin
    Here's the winter wheel setup I'm using for the season here in Chicago area. I called Doc at Tire Rack to sort me out with some tires. I started out about to order Blizzaks and ended up with Continental DWS tires. Tire sizes are 245/40/20....wheels are BMW style 373M. Offsets are pretty close to OEM, with the rear having a slightly higher offset; I'll probably get some 10 to 15mm spacers to widen the rear track a little more.
    I am using the BMW center caps (they aren't pictured), but just finished wrapping them in 3m cf-style vinyl to cover the BMW logo.
    Come Spring, I'll probably be ordering some aftermarket 20" wheels with summer tire. I'll probably be looking to sell my 21" P85+ staggered setup soon.
  2. Dreamin
    Dreamin Member
    SoCal
    Not meant to be critical at all...but why did you end up going with wheels in an offset you didn't want and BMW center caps? Seems like a lot of work of 'fix' these wheels.
  3. Luder94
    Luder94 Member
    Algonquin
    Criticism doesn't bother me...so please be open. At the time I started looking for a winter set of wheels, I didn't like a lot of the options available nor did I like the price point for a set that I'd be using only 3 or 4 months of the year. Finding take off BMW wheels (which all modern BMW wheels are 5x120 bolt pattern and are built to roll the heavy weight 5 series and 7 series cars) was easier and cheaper.
    I only wrapped the center caps so that the BMW logo doesn't show on my Tesla....that took me less than 10 minutes to cut, wrap, and heat shrink; I spent more time cleaning the center caps. 15mm spacers will cost me about $120, and will take me 20 minutes or less to install on the rear wheels. From an effort standpoint, it's been minimal; from a cost standpoint, it's the new all season tires that make up the majority of the cost. The big positive for me is, right now, I know of no other Model S that looks like mine. :D
  4. Dreamin
    Dreamin Member
    SoCal
    Got it. Makes sense. It is a great looking wheel :biggrin:
