Was thinking yesterday that folks focus too much on weight. yeah in racing you push every lever you got to get the most but this is a different context, different constraints.
In consumer, everything is a product design decision and weight is bad if you don't do anything about it. If heavy, you invest more in suspension, add more downforce. The closer you are to the limits, the fewer options you have but are these cars really the ultimate performer within the legal limits? Not really , usability is still a concern.
On the battery side, don''t know if you've seen this M3 battery teardown (it's very long)
A few datapoints from that video
Pack weight 478.1kg
25S long module is 73x11 1/2 x 3 1/2 and weighs 207 lbs
23S module is 67 1/2 x 11 1/2 x 3 1/2 and weighs 191 lbs
(the module info is from a comment to that video)
Stumbled upon this article
https://jalopnik.com/the-bugatti-chirons-engine-alone-weighs-almost-1-000-po-1826728629
Bugatti Chiron
Engine: 961 pounds (436 kg)
Transmission: 273 pounds (124 kg)
So would take a very hefty cut in battery size to match a super heavy ICE powertrain and that would come with lower peak power, much quicker perf degradation as max available power declines , fewer miles added per unit of time when charging, shorter range.
To me , the large pack is a simple and brilliant way of solving a bunch of problems and is also a sales and marketing upside The downside being weight and efficiency but efficiency doesn't matter much in this case and weight, maybe can be dealt with.
If you can beat all competitors and keep the car very usable , why not, they are a business after all.
I was hoping for a more aggressive design but i do get their choices.
Edit:
"Drive a Model S along a winding and undulating road and you feel the dampers working hard to control all that mass heaving around"
They could mask it with very low latency active suspension, and if they have sensors watching the road, it can become preemptive for an ideal ride. They could also offer an ample range of driving modes with such a solution.
