> lol yes I charge in the city [yobig]
If you can get some 200 volt+ charge at work, then I fail to see the point of this thread. It is a 100 mile trip based on a 237 mile Standard Charge.
A rational society would provide a bullet train nearby to get you to work in like 20 min. Give you just enough time to read today's paper. :biggrin:
I see you live in New Jersey. No need to speculate.
...sigh. I always have a problem phrasing things. I think I say what I mean, but it always gets interpreted the wrong way, and for the most part I can't blame them once it's pointed out to me. I suck at communication ...
The battery life of a Lithium ion battery depends on several variables. Among these variables are temperature (both operating and storage), Charging rate and depth of charging as well as state of charge (% of capacity to which the battery is charged) during charge cycles. As well as State of Charge Voltage (The voltage of the cells at a given level of charge). In general the battery can be charged through a greater number of charge discharge cycles when the battery is only partially discharged, then recharged. If you drive about 100 miles (representing about 40% of Max charge range of 265 miles) and then recharge, you will get a greater number of charge cycles than if you discharged the battery after driving 200 Miles (representing 80% discharge). The previous example would reduce the rate of degradation by as much as 20% with charging at 40% vs 80% and even greater if the depth of discharge is even shallower (10%-20%). Based on everything that I have read from technical journals regarding the 18650 Lithium cells upon which the 85 Kw battery pack is composed, providing the user follows Tesla's recommendations regarding charging, a 15-25% reduction in capacity after 160,000 to 200,000 miles would be expected. I own a P85 (#810). However, based on the consumption of gas based on 23 miles per gallon and fuel costs of $3.85 average (my ICE autos use premium fuel). The cost of gas for 200,000 miles would be $33,478.26 plus wear and tear on the ICE, transmission, and suspension. The Tesla has a A/C induction motor which should easily last for well over 1 Million Miles. The quality of construction of the suspension and drive components is among the best of any auto manufacturer (Based on Edmonds Review of Suspension and Under Carriage). Also, when its time to replace the battery in a few years the next generation will probably get 350 to 400 rated miles and cost between $10-$18K. How can you not drive the Tesla 200 miles per day!!
Is it better for battery life to leave the car sit at 40% and use scheduled charging to start at midnight so that it reaches 90% right around 4-5am when I leave, or is it better to immediately start charging as soon as I get home, which would complete around 9-10pm and leave it sit at 90% (standard charge) until about 4-5am when I leave?
oh and the other question I have related to that - I have both NEMA 14-50 and HPWC, which is better to use for battery life?Will charging at 80A vs charging at 40A help or hurt the battery life?
I don't see the advantage in charging for a short period to lower battery temps since putting current into a pack actually raises temps. The pack climate controls should be working to lower temps into a safe range anyway.
I would like to pose this question on other way. I will also be doing a 200 mile round trip 3 to 4 days per week with my Model S. Unfortunately I won't have the opportunity to recharge mid day.
Will I need to use max range mode?
what happens when the battery life gets worse after a few years?
will this be too far to travel in Wisconsin and Illinois winter?
Will I do damage to the battery charging and discharging of this much?
does it matter if I use the high-power wall charger vs the standard 14-50 outlet?
Is there anything else I should be thinking of before going through with my purchase of model s?
What speed will you be driving? You'll be able to make the trip but likely need a max charge in the winter depending on the speed you drive. It doesn't matter if you use the HPWC vs. 14-50 outlet as long as you are fully recharged for the next day. The battery degrades a little with each cycle so since you'll basically be doing a full cycle 3-4 times a week it will degrade faster than someone who drives 30 miles a day but tough to say how much or how fast.
Is there any way you could possibly install even a 14-50 outlet at your destination (even if you had to pay for it yourself)? That would greatly simplify your situation.
This is a great post by ChadS to review as well
Putting some numbers on the factors that affect range
