thanks for the info- the problem is that the computer will not download the parser programs. when I drop into TERMINAL it shows that its there but nothing opens--I really am pitiful at thisIt’s a drag and drop into the terminal window, the terminal window is in utilities
The recent alerts is perfect. That BSM isolation fault is the likely culprit keeping your Roadster from driving sometimes. That error shows up when there's a low path of resistance to ground.I did get into the diagnostics and under recent probs it says DMC FW Invalid shift request Waring and BSM Isolation Fault
I don't think so as it wouldn't cause an isolation fault. Isolation faults are usually caused by dirt or moisture causing the high voltage to find the chassis of the battery, PEM, or HVAC controller. The battery and high voltage system floats independently of the chassis.Could this be one of the riveted packs?
I got the car in December and have had nothing done- I know that the battery was replaced last summer. It was done at Tesla in Texas.The recent alerts is perfect. That BSM isolation fault is the likely culprit keeping your Roadster from driving sometimes. That error shows up when there's a low path of resistance to ground.
Did you have any high voltage work done recently on the Roadster? PEM, battery, HVAC system?
I think that the 220V charging issue may be related to the isolation fault. Can you send me a copy of your log file to review?I got the car in December and have had nothing done- I know that the battery was replaced last summer. It was done at Tesla in Texas.
I am having problems charging it with 220V mostly it won't work but does about 15% of the time. Do you think that this is related??
What is the next thing to be done???
