Here we go for the pictures from the video. Hope this will help you all. I must mention that since the repair, most often the handle won’t extend when I touch it, I need to have it extend by touching the front door handle which is not a big issue for me. Unless it completely fails again, I’m not putting my hands repairing the rear door handles as it’s very tight spaced compared to the front door handles.
In a side note, if I may somewhat pirate my own thread, I also repaired a pivot gear on my front right door but since, the handles stays extended(without causing any other functional issue else than aesthetics). If any of you know of what adjustments I need to make to correct this, I’d be grateful. Just as an added note, if we pull ever so slightly on it it retracts and we simply have to press on it for it to extend once more. I must add that the friction point must have «dulled»(correct English?) itself a bit as it’s less and less frequent for this situation to occur (it’s been six months since I repaired it but being a bit busy, haven’t had much time to look at it). Also not knowing how to solve the issue did not help motivate me to find time to tackle the issue. You all have a great end of Sunday
