Is this the better battery? The “C” version?
Yes, it better than a remanufactured battery.
SC said they will adjust the price from 17K down to the original estimate which was 13k.
which of course did not happen!!!
It’s the newest known revision of the “new” 350v replacement pack, so yeah that’s about as good as it gets.Is this the better battery? The “C” version?
Good to hear!It’s the newest known revision of the “new” 350v replacement pack, so yeah that’s about as good as it gets.
Well, I picked it up a couple hours ago and then it completely shut down again!! Here are the codes. Brand new battery!Good to hear!
Damn that sucks. Did you visually confirm that a 1014116-00-C was installed?Well, I picked it up a couple hours ago and then it completely shut down again!! Here are the codes. Brand new battery!
Update:
Well, I picked it up a couple hours ago and then it completely shut down again!! Here are the codes. Brand new battery installed. No idea what is going on here!
Make me think it wasn’t my battery in the first place. I’m at a loss right now, pulling my hair out. Not sure how to address this with the SCI don't think it's your battery. Looks to me it's your drive unit (DU).
**** ... another 10 grand. Hopefully not.I don't think it's your battery. Looks to me it's your drive unit (DU).
Sorry you're going through this.Make me think it wasn’t my battery in the first place. I’m at a loss right now, pulling my hair out. Not sure how to address this with the SC
No, I did not confirm. It’s on the paperwork. I didn’t check the actual battery. Not sure what it could be. Was working fine for a while till I got home and then went out again. Broke down on the highway.Damn that sucks. Did you visually confirm that a 1014116-00-C was installed?
I think the DU was replaced in 2019 under warrantyIs it the original DU?
It happened while my wife was driving. Completely shut down. Hopefully it’s not the DU. I can’t afford another 8-10k. Luckily they gave me a loaner. The least they could do. Do you all think it was something different all along??**** ... another 10 grand. Hopefully not.
Which code would indicate the DU?
It looks like the BMS codes happened while it was serviced.
BMS_f033
The Battery Management System (BMS) will trigger this alert when it senses a loss of contactor power while the contactors are closed. The BMS assumes that it could be because the pyro fuse on the contactor power supply signal blew during a crash.
This may trigger while a vehicle is in Service and the contactor power supply loop has been pulled.
BMS_f062
The Battery Management System (BMS) has detected that there is a power supply issue with the contactor.
None of the codes that you showed indicate that it's the battery or DU.It happened while my wife was driving. Completely shut down. Hopefully it’s not the DU. I can’t afford another 8-10k. Luckily they gave me a loaner. The least they could do. Do you all think it was something different all along??
They just got done installing a new pack! Brand new 90kw and then this happens! Doesn’t make sense.None of the codes that you showed indicate that it's the battery or DU.
Hopefully it's the battery and they install a new pack.
UPDATE:
Well they fixed it. Hopefully. Apparently it was a connection with the 12V. Posting their explanation.
