2014 Model S - panoramic roof leak
I have a 2015 Model S P85D with sliding panoramic sunroof. I just started getting a minor leak coming from the rear driver side dome light. It happens when I take it through the carwash (about 5-10 water drops). Have not tested yet in rain. The front two drain tubes are cleaned out and drain perfectly.
Is it maybe the rear roof drain tubes? If so, where are they located? The seal on the fixed (rear) glass portion is sagged a few millimeter on the driver side by about 8-10 inches. I have not brought into SC yet and wanted to see if there was an at home fix I should try first. It is out of warranty.
Thanks everyone.
This is the Model 3 section, and no Model 3 ever had an opening sunroof. It sounds like you could have rear drain tube troubles, but neither of my previous Model S cars had that issue so I'm not completely familiar with cleaning the tubes or where they leak when "backed up."
You're probably better off asking here: Model S
Good catch....I meant to post in Model S section. Thanks for pointing me in the right direction.
