Decided to do a 100% charge today and got it to 230miles at 97% charge. I am not aware of the what the initial rated mileage was to compare for battery degradation. Can anyone comment? Thanks!
I have a S75 and my 90% is 354KM or 220 miles. My 100 should be about 244.4 miles
Technically, you're right, but the battery capacity should directly convert to rated miles. If you really have 68kwh, then you haven't seen much degradation at all, given that usable capacity for a new 70 was about 68.8 kwh. I would guess you're 100% is about 237 miles, which is only about 1% degradation from the EPA rated 240 for the 70d. You are doing much better than I am. My 70d is at about 64.5 kwh, and about 225 miles at 100%.It’s not the miles but what’s the kw remain on the pack? My 2015 70d bounces between 67.9 and 68kw and I just clicked over 40k on the OD.
Pack capacity is what’s key here
the original Model S 70 (RWD) introduced in 2015 has an EPA rated range of 230 miles.Decided to do a 100% charge today and got it to 230miles at 97% charge. I am not aware of the what the initial rated mileage was to compare for battery degradation. Can anyone comment? Thanks!
View attachment 271123 There’s your answer from September on my 2015 S70 with around 39K at the Harris Ranch Supercharger. I think this was a little higher than I had ever seen but it was about 80 degrees out so the battery was kinda’ optimized. On other road trips I believe 230 is what I’d see. We charged while we had a long lunch. I wanted to see if we could hit 236, it kept stopping and starting the slow charge and I think that was what “balancing” the batteries is all about. After 10 minutes my wife said “ok, enough already, let’s go”. Maybe, just maybe, there was another mile or two in it.
the AWD version Model S 70D from the same year has a rated range of 240 miles
(my 2yr old 23,000km 70D at 100% charge still shows 384~386km, i.e 238~240mi)
btw this is a different battery than the 75 introduced later (a couple people above mentioned the 75), and so not directly comparable
Can you and the OP please get the units right?It’s not the miles but what’s the kw remain on the pack? My 2015 70d bounces between 67.9 and 68kw and I just clicked over 40k on the OD.
2.5 years, and 51k miles later my 100% is around 232 miles. So about about a 3.5% degradation from the EPA rating in 2.5 years and 51k miles, I think it's good.
Man, I wish I had one of these 70 packs. My “75” has lost over 8% capacity in one year and 36k miles. Super disappointing.
Maybe that's why mine is showing so much (well besides being a real 70, without the silicone anodes). We drive a lot, and I don't baby the car. So I charge to 100% before every trip, and I get it to down to the single percent digits on most of my road trips.I’m 1.5 years in and I’m down about 5%. Have you run your pack down and up to 100% a few times? I found that optimisation kicks in and you end up with some higher values after a few cycles.
