2015 Model S 70D parts for sale
2015MDLS
New Member
Mar 22, 2020
Kansas
I ended up with a wrecked 2015 Tesla Model S 70D that had been stripped for parts to repair another car and have many parts left. Unless otherwise noted parts came from the 2015 70D. Parts have not been tested for function as I do not have another car to test them with, but do not appear to have any damage unless noted. Prices are VERY negotiable. Parts are priced about half of most other places to sell quick and free up some shop space. Shipping will be extra and actual cost to ship by USPS flat rate, multiple items can ship together. If you would like pictures of a certain part let me know. Part numbers listed are from the actual part. Thanks for your time.
CONTROLLER HVAC NON AQS 6007366-00-B $25
HOMELINK MODULE 1005371-00-B $40 85D
PARK BRAKE CONTROLLER 1007618-00-E $50
IONIZER 1032817-00-A $10
THERMAL CONTROLLER 1034215-00-A $30 REV 01
CHARGE PORT NO CABLES 1026041-00-K $45 85D, 1 MOUNTING TAB BROKEN OFF
HV FUSE 450A 1024279-00-A $75 #1
HV FUSE 450A 1024279-00-A $75 #2
COMPLETE HEATER CORE ASSY 6007385-00-J $75
FRONT & REAR UPA MODULE 1048476-00-C $75 W/ BRACKET
THROTTLE PEDAL BE5C9F836-AA $50
DOOR CONTROL UNIT 1003101-00-E $25 #1 H/W VERSION 14
DOOR CONTROL UNIT 1003101-00-E $25 #2 H/W VERSION 14
MONO CAMERA ASSY 1038482-99-J $75 W/ BRACKET
BODY CONTROL UNIT 1010906-00-F $75 85D H/W VER 20
RADIO NORTH AMERICA 1004787-01-C $50
COOLANT SENSOR 6007371-00-A $5 #1
COOLANT SENSOR 6007371-00-A $5 #2
HV CIRCUIT CARD 1047340-01-C $50 85D, REV 01, L4 CHIP CORRODED
HV CIRCUIT CARD HARNESS 1041309-00-F $15 85D
ASSY, HV ANCILLARY UNIT 1065894-00-B $125
HV BOX 1028843-01-C $100 REV 01, MISSING 1 COVER BOLT
ASSY GEN 2 CHARGER MDLS 1014963-00-L $250 1 DAMAGED CONNECTOR
CAR SIDE BAT COOLANT QD 1003117-00-G $20
3 PORT COOLANT VALVE 6007384-00-B $25 VALVE AND ACTUATOR
ASSY, HV JUNCTION BOX 1048910-00-C $125
HEATER FLAP MOTOR D267-AP9BA02 $15
BOSCH MOTOR & GEAR 0 390 203 280 $15
FAN CONTROL MODULE 6008953-00-B $40 85D
HV BAT CONNECTOR 1022565-10-E $50 TERMINAL HAS SLIGHT BEND
DUCT ADAPTER, DR 1008282-00-A $10
HARNESS REAR SEAT 1024956-02-C $25 HAS SOME DAMAGE
WIN WASHER RES 1005400-00-B $40
ASSY HARNESS GEN 2 JB 1030182-00-E $50 JB TO GEN 1 NA CP
FJB TO HVJB HARNESS 1030582-10-G $100
SRS SENSOR 1005274-00-B $20 #1
SRS SENSOR 1005274-00-B $20 #2
SRS SENSOR 1005274-00-B $20 #3
SRS SENSOR 1005274-00-B $20 #4
DOOR SRS SENSOR 1005275-00-A $20 #1
DOOR SRS SENSOR 1005275-00-A $20 #2
KEYLESS ANTENNA 1005627-00-B $20 W/ BRACKET
AC SENSOR 2CP80-1 $5
COOLANT PUMP $30 #1, NO BRACKET
COOLANT PUMP $20 #2, CRACKED IMPELLER HOUSING
COOLANY PUMP $20 #3, CRACKED IMPELLER HOUSING
COOLANT PUMP $40 #4, W/ BRACKET AND RUBBER RING
COOLANT PUMP BRACKET $10 W/ RUBBER RING
BLUE HV HARNESS $25 BLUE CONNECTORS
WINDSHIELD RES CAP $5
WIN RES LEVEL SENSOR $10
HV FUSE HOUSING $20 #1, HAS 1 BROKEN CLAMP
HV FUSE HOUSING $20 #2
UNDERHOOD HARNESS/ FUSE BOXES $200 HAS SOME DAMAGE AND CUT WIRES
LEFT SIDE INTERIOR HARNESS $75 HAS SOME DAMAGE AND CUT WIRES
RIGHT SIDE INTERIOR HARNESS $75 HAS SOME DAMAGE AND CUT WIRES
MISC HV CABLES $75 7-8 ORANGE HV WIRES W/ CONNS
MISC COOLANT HOSES $25 VARIOUS SHORTER HOSES
