2016.5 90D Charging Questions
Discussion in 'Model S: Battery & Charging' started by PDX-Conquest, May 23, 2020.
  1. PDX-Conquest
    PDX-Conquest Member
    Tualatin, OR
    Hey all, first time, short time. I'm looking at purchasing a used 90D with 55K miles on it (my first tesla). At the non-Tesla dealership where I found the vehicle they charged the car all night and it only showed a range of 252 miles. Is this an indicator of issues with the battery or is there a setting that needs to be changed? I'm looking for any help you can provide to help me make this decision. Also, any idea how I verify if this vehicle has free supercharging? Thanks
  2. paulk
    paulk Member
    hartford, ct
    there's a setting for the maximum charge, and it should usually not be set to 100% (that's bad for the battery if done too often). also, charging all night on a standard outlet might have only put 50 miles of charge on the battery.
  3. PDX-Conquest
    PDX-Conquest Member
    Tualatin, OR
    Thanks Paulk. I had them change it to Trip in the charging menu. Will it matter if it’s been selected to range mode while charging as well? Thanks again
  4. paulk
    paulk Member
    hartford, ct
    Range mode doesn’t change the charge, but it does change how many miles it reports by a small amount. My car has been in range mode since the day I got it.
    You should have the dealer charge it to any level really, then extrapolate. If it’s set to 50% charge and reports 135 miles, then a full charge is 270. I don’t know the ideal range on a 90D, I think 285. It’s likely it degraded to 265, which is fine.
  5. PDX-Conquest
    PDX-Conquest Member
    Tualatin, OR
    I’ve moved on from that vehicle and now looking at a similar 2016.5 90D. This one, when charged completely shows a range of 325. Can that be accurate? I thought they were only rated to 290ish. Thoughts?
  6. ucmndd
    ucmndd Well-Known Member
    There is a settings toggle between “rated” and “ideal” range. The car you’re looking at is almost certainly set to ideal.
    • Informative x 2
  7. gsteele
    gsteele Member
    The car is set to ideal range, not rated, probably. Flip the setting to rated and see what it says. A full charge on my 2016 90D with 60K miles is about 272 rated miles. It was 294 when new I believe.
  8. PDX-Conquest
    PDX-Conquest Member
    Tualatin, OR
    Thanks, where would I find that setting?
  9. ucmndd
    Controls -> Display
  10. gsteele
    gsteele Member
    At the bottom of the ‘Display page’ where you can select energy to display in percent or miles.
  11. PDX-Conquest
    PDX-Conquest Member
    Tualatin, OR
    Thanks for your help
