2016 Model S Shot Down HV Battery Fault. ( Battery replace )
Hello, last week my 2016 model s 75 shut down and had to be towed to the dealership.
The determined the HV battery needed to be replaced and so I received a remanufactured one.
I'm concerned as it appears that the battery is older than than my current 2016 battery and so I'm wondering if this will cause any issues later on?
If its remanufactured, I would assume it's in good condition, but should I be concerned that it is older?
Where can I find out what year the battery is from? ( Replaced battery 1102xxx - 01 - A )
This is from TeslaRati -> (if something should ever go wrong and you’re given a replacement battery pack by the Tesla Service Center, make sure you do not receive a refurbished A pack or any pack labeled with a version older than your existing one.)
Thank you!
They are only talking about an 85 kWh A pack. The A packs for the other sizes should be just fine.
Reactions: croman
