2016 Retrofit Radar Detector Location?
Discussion in 'Model S' started by BigTonyTones, Feb 7, 2017.
Tags:
  1. BigTonyTones
    BigTonyTones Member
    Los Angeles
    Hello Everyone
    Just finished wiring my 9500ix. I did notice range is not what it used to be due to the coating on the windshield.
    Does anyone know what area of the windshield is not coated?
    I found multiple threads on older Teslas, but not the retrofit model.
    Thank you very much for your help
  2. oktane
    oktane Active Member
    I believe it is all coated. Best to install a 9500ci.
  3. Drewflux
    Drewflux Member
    Australia
    Not too sure on the refresh model, i have heard of issues with toll tags. I would suggest a handheld gps or use your phone to find a good spot. On an android phone, select settings, about device, status, network. It will show network signal as you move it across the windscreen.
  4. BigTonyTones
    BigTonyTones Member
    Los Angeles
    I was debating it. Just wasnt sure where to cleanly mount all the receivers since there is no front grill on the refresh
  5. oktane
    You can still mount it on the front frame behind the bumper plastic.
