Can others verify that the "keep your hands on the wheel" time is ultimately the same as it was in 17.4, or are others having the issue where it requires you to keep the hands on the wheel at all times. That is a deal breaker for me.
Generally the same.
On that note, I did some more driving tonight. Impression is largely the same as last time: it seemed absolutely perfect on the freeway but could use some work on local roads. And while lane changes are the standout feature, it's also much more smooth and stable going through lane merges and splits and generally better at staying in the lane. I've taken my nearby challenging exit(3 pretty tight curves going from freeway to a bridge), that it was never able to handle before, multiple times without needing to disengage on any of them.
On the other hand, it no longer reacts correctly to stopped cars from far away. It seems to consistently tap on the brakes hard twice and then accelerate towards the stopped car. I don't have the guts to let it go and see if it'd stop in time.
