So last night I had my second software install failure for this update. I’m currently on .42 and they’re looking into whether the jump from .42 to .48 is creating an issue. I never got the .46 update.
Yup, they've been working with me on this. They sent out the 2nd update that eventually failed. They're researching what went wrong. Hopefully this doesn't require a visit to the SC.Contact Tesla.
Weird that a faulty door module would result in a firmware failure.
I guess because I don’t think of the door module as being a recipient of a firmware update.Why? If the door module fails to update properly the update as a whole has failed. (it is possible the changes to the central module requires the door modules have the new version.)
summon should not work at all if an essential safety item is inop.They work erratically. Summon won't react to things in front if they are non functional.
Same here.. I've tried everything, even sniffed the WiFi traffic... went to the SC and connected to their WiFi for about an hr and SpC'd and still nothing...I'm still on .42 :/
I lost the lifetime KWh/Mwh number under the odometer after 48. Anyone else?
So I was lucky enough to have mobile service bring me my new snow tires and wheels, over 250 miles from the nearest service center. I really wasn't expecting that when I ordered them from Tesla. When done, I asked if I could be upgraded to latest firmware. He did it on the spot through hardwired connection to his laptop. Install seemed to go without problem, but I have now been without self-driving or TACC. I figured the cameras were re-calibrating, but it has now been over 150 miles. Everything else is working fine. Easy entry, etc. Headlights stay on all the time, and auto high-beam is not active (assumed because camera not active), but all other software working as usual.
Should it take this long to re-calibrate, ever? I've never had this happen after any prior update?
Tin foil hat alert.
So a couple of odd things happened in the past 24 hours, and I was curious to know if anyone else was in the market for a metallic chapeau:
1. Whilst at the SvC yesterday, with mobile access disabled as they are known to do, toward the end of the visit I get a “Software update completed” push notification from the app. An hour later, I had to reactivate mobile access via the touchscreen which is to say it appeared to be off for the duration. Meaning that apparently we still get push notifications with mobile access disabled. Ok fine.
I noticed that there was no alarm clock icon, which implies that they had neither staged, let alone applied (which would have been odd anyway) an update. Further, 2 updates had been applied in the past 10 days - .46 at the SvC and then .48 via LTE. With no sign of .50 in the wild yet.
So I ask - hey, was an update applied, because I got this here message. Normally, y’all just stage those and I apply them later.
They confirmed that yes, they had applied an update. I noted that the version number hadn’t changed (it matches the thread title), and asked if they had simply reapplied the same update (which would have been weird enough, since usually they just say “you’re up to date.”)
Now here’s where it gets truly weird. We’ve been treating these relatively new appended hashes as indicators of unique patches, right? Well... what they said was that the last update was “14” and the update applied now was “44”.
Since those numbers don’t match up with anything recent, I asked them to double check. They confirmed.
So........ what this appears to imply is that the specific build can change behind the scenes and be distributed with the same hash.
Egad. Might explain some of the variable experiences if true. Just seems highly unlikely.
Now for the best part.
About 6 hours later I get a notification that maps have been updated. Well, okay, that’s the 3rd or 4th time I’ve noticed that in 3 years.
Fast forward to now. I just backed into an SC space. Nothing weird there. Except then the charging screen appeared and informed me that the charge port was open.
Cue the Barry White music, folks.
I haven’t reproduced this yet, clearly, as I’m still charging. Geofenced auto-opening charge ports?
Just wanted to illuminate both oddities (different builds being distributed with the same hash - which just seems very odd, not to mention fraught with peril, and the auto-opening of the charge port after entering an SC space), in case anyone else experienced the same.
The latter could be a preparatory step toward Barry White charging, yes?
Either that or maybe my fob got pressed in my pocket and the whole thing is a coincidence. And it’s possible that the SvC folks were mistaken in which case that explains that.
In any case, unless any of this gets reproduced, please note that I did not bring enough tin foil for everybody.
