Hi There,
Picked up a second hand 2017 Model S 100D - Irritatingly neither of the front USB ports work for power or for music. The rear passenger USB ports are lit and work fine (Don't appear to do data). The 12V cigarette style port also fine.
I'm thinking probably fuse though I've yet to find anything obvious!
https://teslamotorsclub.com/tmc/attachments/fuse-box-pdf.433799/ Is a PDF of the fuses. Both Frunk and Right hand side footwell (Same on the UK it seems, though the pedals get in the way slightly)
Nothing on the fuse list says USB - A quick go with a multimeter and they seemed OK, but if anyone knows the specific fuse here, I could try a swap anyway
Any other ideas most gratefully welcome - I've tried looking and pulling the odd trim on the factory fitted console (there a PDF for the retrofit one, helpful, but different) but have yet to find anything obvious or even quite where the USB ports go to (All the way to the MCU or is there an interface)
I did find a curious powered fan thing above the USB ports in the console behind a kind of speaker pattern of holes. No idea what it is!
Also found the Data port when removing the cubby along with a loose aerial type connector (Maybe CAN) but nothing to plug into, so probably loose on purpose.
Would *REALLY* like to USB music working as Spotify is great, but data isn't always there (GF lives in the boonies) and UK radio Irks with adverts. I've listened to a few audiobooks since getting the car though!
Ta,
Lee
Ta,
Lee
