2017 MS - car will not turn off - anyone else experiencing this?
Discussion in 'Model S' started by whitex, Jan 26, 2017.
Tags:
  1. whitex
    whitex Active Member
    Seattle area, WA
    Started experiencing a new problem on our less than month old Model S - after exiting the car, it will not shut off. I can lock it, I can get in and out of the car, open close doors, nothing changes - the car will not turn off until it's rebooted with the double thumb salute. Nothing is on the seats at all, so it's not the seat senor being triggered (unless of course it's broken).
    Trying to figure out whether this is a software issue or a sensor problem, hence my question to see if others are seeing it? Firmware version 17.3.2 here.
  2. AEdennis
    AEdennis Active Member
    Just a thought...
    Have you tried to do the Power off button on the touchscreen.
    Or perhaps a soft reset
  3. whitex
    Seattle area, WA
    "Double thumb salute" is the soft reset - it solves the problem temporarely, only to come back a day or two later. :(
  4. ev-now
    ev-now Member
    Denver, CO
    What are the symptoms of it being ON? Do you mean both displays are active? Do they display anything unexpected or are they missing anything?
  5. whitex
    Seattle area, WA
    Just on, both screens on as if someone was in the car, music playing, climate on. Car locked at least. It never times out either (still on an hour and half later).
  6. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    I noticed tonight that my 17" display had stayed on. I opened and closed the driver's door, but that did not have any effect on the display. I wound up resetting it, and then when I left the car the display turned off normally.
    I'm currently on firmware 8.0(2.52.22).
    If it happens again I'll post again.
  7. whitex
    Seattle area, WA
    Sounds the same. Resetting it seems to restore normal functionality, until next time it gets stuck.
  8. wdolson
    wdolson Supporting Member
    Clark Co, WA
    Did you install a new phone app? I tried one and while it was in memory on my phone it would not allow the car to shut off. When I killed the app in phone memory the car shut down normally.
  9. NikeWings
    NikeWings Active Member
    #9 NikeWings, Jan 27, 2017
    Power the entire car down from the touchscreen. Give it 5 mins or so and then re-enter and hit the brake.
    FYI Edit: Touch Screen>Controls > E-Brake & Power Off > Power Off.> Exit Car>Wait 5 mins
  10. whitex
    Seattle area, WA
    What will that accomplish?
  11. NikeWings
    Resetting the dash/CID/controls as previously suggested and you called the double thumb salute won't help problems unrelated dash/CID/controls. You can drive while doing that. The power down process resets the entire power system of the car, which if having trouble 'shutting off' the car might be helpful. Tesla SvC had me do this when my AC continued to run well after exiting the car. They referred to it as a power re-boot and my A/C worked fine afterwards. Only take a few minutes and thought it might be worth trying. And BTW, its the same process you would perform in case of an emergency that required you to kill the car's power.....at least thats what SvC told me. :rolleyes:
  12. Electric700
    Electric700 Active Member
    Florida, United States
    WhiteX if the shutdown doesn't solve the problem, I think you should contact your Tesla Service Center. The behavior you have encountered shouldn't be happening.
  13. ThisIsTrue
    ThisIsTrue Re-member
    'Western Slope' Colorado
    I call that a cold reboot. Hitting the brake pedal is what does the power-up afterwards.
    Road service had me do that when I was setting off for a 4,000-mile road trip, and after supercharging all "driver assistance features" were suddenly offline. Rebooting fixed everything, and I had no trouble for the rest of the trip.
    I had to do it twice, though: the first time, he hadn't told me to wait, and I hit the brake pedal too soon. Had me do it again and "wait 2 minutes." That worked.
  14. GasKilla
    GasKilla No Gas Know Peace
    Los Angeles, CA
    I can say from experience the touch screen power off solves a lot of problems, try it because that's what tesla support will also ask you to do
  15. whitex
    Seattle area, WA
    Will try the car-off-reset. I hope it helps as the problem seems to have gotten worse - the car was parked in the garage, everything off and good. Then few hours later I hear music from the garage, I go look, the car is on but this time unlocked! The handles presented without a key and I was able to open the door. Closing the door didn't turn the car off. I rebooted the ivi and closed the door. Once rebooted the car locked itself. This is rather concerning to me. I'm worried the car will wake up and unlock itself when parked in a public parking lot somewhere and someone who will hear the radio and realize the car is on will hit the door handles and get in. :( I wonder if this is related with the car randomly not able to recognize the key is in the car (e.g. it lets you in, you back up, then it won't let you drive because it can't see the key, then a minute later it detects the key and you can drive again). We have an SC appointment next week for something thing else, but I hope they can fix this one too.
  16. whitex
    Seattle area, WA
    CORRECTION to my post above. The car didn't unlock itself. Turns out while the car was in the garage, someone from the house went to retrieve something from the back seat - that was the unlock event. The car didn't re-lock itself once the key walked away though, plus it wouldn't turn off either, so there is still something wrong but at least I'm not worried about the car unlocking itself while parked - worst case scenario it will drain a few miles from the battery while keeping the climate on.
  17. zambono
    zambono Active Member
    DC
    Get rid of any third party apps and then try
  18. wdolson
    Clark Co, WA
    Here is another thought. Since about the time of the last firmware update my car has been doing some odd things like the door handles didn't auto present and a few other things. I discovered this afternoon that my SO had accidentally left the spare key in the console. When I removed the key, the car went back to its old behavior. Is it possible someone left a key in your car?
  19. whitex
    Seattle area, WA
    Spare key locked in drawer, actual key was in the house, so unfortunately not.
  20. Lightmatrix
    Lightmatrix Member
    Houston, TX
    I had a similar situation a while back, took it into service and they replaced the MCU.
