What is the horsepower rating for this car and does the P have a lot more power.
Can you buy a software upgrade that will add the ludicrous mode to the 100S
Note: This feature currently requires accessing the site using the built-in Safari browser.
The P100D has a completely different rear motor, so a 100D can't be upgraded. (Well, except at great cost, and not by Tesla.)What is the horsepower rating for this car and does the P have a lot more power.
The S100D will put out 430 kW, which is equal to 577 hp. The P100D will put out 581 kW, which is equal to 779 hp.What is the horsepower rating for this car and does the P have a lot more power.
Does anyone know when did Tesla start building the 430kw, uncorked 100Ds?
Around the same time as they announced new back seats and 75/75D uncorking
You should take a proper test. A box or the power tools app you can find on the App Store for iPhones and test the acceleration. Uncorking should be around 3.6sec from 0-60/62mph. My 75RWD delivered in December should have been uncorked from factory but I took it to the service centre and they uncorked it for me so now it is faster.My S100D was built mid-October, and came with the new rear seats. So this should be uncorked from the factory, right?
I floored it a couple of times, but I don't think I saw the power-meter max out (it didn't reach the interpolated 400ish mark). However, I'm on winter tires, cold weather and I had 60-70% SoC.
Would there be an app at Google Play for android and if so what is the exact name of the app.You should take a proper test. A box or the power tools app you can find on the App Store for iPhones and test the acceleration. Uncorking should be around 3.6sec from 0-60/62mph. My 75RWD delivered in December should have been uncorked from factory but I took it to the service centre and they uncorked it for me so now it is faster.
I believe that there is one called "Dashboard" or "Tesla Dashboard". I use "Powertools" on iOS.Would there be an app at Google Play for android and if so what is the exact name of the app.
my 100 D seems to be very fast.
I Own a Dec 2017 100D and it is far from slow, today I did a quick timed run, I even did not accelerate full from the start, 0-100 kph was 3.552 seconds. Full acceleration was not possible due to the little wet road, so I pushed the throttle gently. It also was a bumpy "Belgian" road.
The 2.5 - 2.7 range can be reached with the p100D only in ludicrous mode and it has to warm up. So I think for daily use en p100D will be in the 3.0-3.2 sec range.
But indeed the P versions have different rear motor, I saw it myself in the factory, had a factory tour in Holland before.
For me the P was not worth the 30k extra.
