I will start from the beginning, car didn't want to rise, found errors with LF ride height sensor, found the connector not seated properly.
Reconnect the ride height sensor and errors went away. Also air compressor started raising the car maybe an inch or so but 5 seconds later it stops and giving these two errors:
Maybe anyone have an idea where to start searching? It measures pressure in the solenoid block but not sure how pressure can get to high if car seems not on very high when compressor stalls. I also find it strange it gives 'font axle to low' while it can measure each sensor independently. Could the solenoid valve block be faulty?
Searched on fault codes but literally couldn't find anything on this issue
