2018.24.1 broke my maps and navigation
Discussion in 'Model S: User Interface' started by tinm, Jul 20, 2018.
  1. tinm
    tinm 2020 Model S LR+ Owner
    New Mexico, USA
    Bug report for a 2013 Model S 85 now running 2018.24.1 12dd099.
    Literally the moment I turned on the car once firmware 2018.24.1 was successfully installed a few weeks ago, I noticed a problem in the Navigation map on the 17” screen: it wouldn’t load any map imagery. All I saw was the gray grid, and the red arrow where the car was in my garage. If I zoomed way way out, I would see New Mexico, great. But if I zoomed back in, or pressed the button to orient North, it would zoom in and default to an empty grid again.
    (Obviously the two gray vertical vars are an artifact of the camera not the 17" Tesla screen):
    What I have noticed ever since is very spotty map coverage. It doesn’t matter where, and it is independent of the communications bandwidth at the moment (in the garage I have full blazing wi-fi and the car is plenty happy with it). Around town or on an interstate I usually get 3 to 5 bars of cellular in the car, which prior to 2018.24.1 was always plenty to load maps as I moved through an area.
    We recently drove to Denver for a short vacation, and I used the Nav extensively to find places around Denver. What I noticed is that whenever I got closer and closer to a destination, from 10 miles to 1 mile to a few blocks, the Nav would do its thing of auto-zooming to show more detail as I got closer — love that feature. BUT… as it auto-zoomed, it would invariably start losing map detail, and large swaths of the map would just default to gray grid again. By the time I'd arrive somewhere, I was . . . nowhere on the map!
    This is the normal behavior with the maps now, ever since I downloaded 2018.24.1. It happens all over the place, anywhere I go. To be completely clear, it happens about 95% of the time. Once in a great while when I am using Nav to get somewhere, it will properly auto-zoom all the way to the destination with correct map detail. But that’s like 5% of the time now. The rest of the time the map is full of empty spaces with no detail.
    Is this a known bug? Anyone else seeing this?
  2. Lukez
    Lukez Member
    Ontario
    Same here, I have a 2013 85 and noticed the same behavior. Zooming in and out is useless as it won't load like you noticed, also traffic isn't up to date most of the time.
    This update made my nav pretty useless for daily driving/traffic monitoring.
  3. animorph
    animorph Active Member
    Scottsdale, AZ
    You did try a reset or two, right?
  4. Shateam
    Shateam Member
    NJ
    I can confirm the same behavior. Maps are pretty much useless for me right now.
    Dec 2016 MS 90D and on 2018.24.xxxxx
    Have tried the scroll wheel reset but no luck.
    Hoping 2018.26.xxxx resolves this.
  5. Altes
    Altes Member
    SF Bay area
    im on the same SW nov 2016 delivery MS60, my maps are greyscale as mentioned elswherre and traffic is slow/no or WAY late in updating Maps regen speed seem OK but was never great
  6. tinm
    New Mexico, USA
    yep, resets did nothing
  7. Cirrus MS100D
    Cirrus MS100D Supporting Member
    Pennsylvania, USA
    I had the exact same issue on the exact same hardware and firmware version. Ultimately, I did TWO reboots in close succession because after the first one, my ultrasonic sensor chime wouldn't shut up, even though I was nowhere near anything. After the second reboot, my maps now load normally again and I can now zoom in and see the detail down to the street level. Sometimes it bogs/caches a bit and I see gray boxes, but since Wednesday night after the 2x reboots it's been fine. (I also do the binacle or whatever you call the thing above the steering wheel by pressing and holding the two buttons at the same time whenever I reboot the MCU.)
  8. tinm
    New Mexico, USA
    hmm i will try more reboots
  9. JD01
    JD01 Member
    Chicago
    Yes, it's fixed in 2018.26
    Contact the SC and they'll push it to you early.
  10. tinm
    New Mexico, USA
    FYI I rebooted again and the map and the nav and the auto-zoom all work now!
    So it took multiple reboots since the install--not just one--to get a fix.
  11. JD01
    JD01 Member
    Chicago
    Rebooting was only a temporary fix for me. The problem came back whenever the maps auto- zoomed in or out... Like when you transition between highways and surface roads.
    If the problem comes back for you, pinch to zoom or toggle satellite view on and off... Both made the maps refresh for me and were a lot quicker than rebooting the MCU.
  12. JRMW
    JRMW Member
    Minneapolis
    Thanks. My maps also don’t work as I posted in the other thread
    I’ll try the double or triple reset trick
    Thank you all!
  13. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    Broken for me too. Tesla seems to have no real regression testing.
  14. democappy
    democappy Member
    Charlotte, NC
    Does this include fixing the traffic never being up to date?
  15. JD01
    JD01 Member
    Chicago
    TBH... My nav has been too up to date for the last few weeks and I haven't noticed a difference in 26. For me, it's showing traffic jams at stop lights. I can watch the red go away for cross traffic when I'm the one who's stopped.
  16. Robin H
    Robin H Member
    Carrabelle, FL
    I had the same problem. I just waited it out. Today the screen is back to normal and google maps displays properly.
