  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
2018 m3 LR 4 year Maintenance recommendaiton
Hi we have our 4year maintenance service that we asked Tesla to do which they are charging for. Can you please let me know if you recommend anything that is missing. I have the following so far. Also how much I should be paying
  • Wiper blade change
  • HVAC Filter change(clean foam spray )
  • Change/Check break fluid (if its full/clear do you recommend any action?)
  • Lubricate and clean break pads
  • Duel Motor lubricate oil ( is this needed? whats the charge?)
  • 12 v battery change ( should we get this changed? whats the charge)
jjrandorin
Moderator
Nov 28, 2018
16,684
21,971
Riverside Co. CA
As far as your "whats the charge?" questions, since labor rates may be regional, you will need someone from your region to answer that (or ask tesla to send you a quote for the work, which would be the most accurate method to determine what it will cost).
