2019.32.2.1 is now rolling out
Landshark70
97
52
Bergen aan Zee
had the smell for the first time yesterday. normally run the a/c in advance as well. and use to have the cabin overheating always on even when not selected but that went away with a previous update i guess
I found some more detailed release notes on another forum. They indeed made changes when the ventilator kicks in:
marksvend
117
326
Issaquah, WA
The vampire drain on my Model S running 2019.32.1 parked in the garage has been about 4% loss per day. Sentry Mode is disabled. After getting the update to 2019.32.2.1 yesterday it only lost 1%.
Reactions: VT_EE
towndrunk
287
203
Fargo, ND
I just got it this afternoon, seems pretty much the same as before. Still here waiting for some way to change the sensitivity of the auto wipers :D
I'm on 32.2.1 and had the wipers running every 3-4 seconds with no rain on the (clean) windshield. I've never had that before. I rebooted, to no change and finally turned the wipers off. That's my winter mode... I just turn them on when needed by pressing the end of the left stalk. Since I'll be treating both of our windshields tomorrow, I suspect chatter may be a problem for awhile, so leaving them off will help my sanity.
Blucenturion
277
99
Humboldt Co., CA
i'd like to hear from you this winter, about your range in Fargo. My longtime colleague hailed from there. His railroad closed during winters, he came to Long Beach and worked at the Douglas plant. The name Fargo always catches my eye, since then.
Reactions: towndrunk
VT_EE
2,019
2,408
Maryland
One of my biggest challenges is that I cannot connect my car to my WiFi - I live in a condo with a separate garage and thus far have not been able to get the
I run my A/C everyday. I am so grateful that I have never experienced the “smell” issue. So sorry for those of you that have experienced it.
Same here. 21k miles and no smell. Maybe it’s my deodorant.
towndrunk
287
203
Fargo, ND
When temps get below 0F and I've been parked at work for 8+ hours, there's no regen for the trip home and acceleration becomes granny-on-a-walker mode. Range at highway speed gets low enough where I assume half of the range shown in the car is available. i.e. a 100 mile trip at 60 to 75 could take close to 200 miles of battery. When plugging in on a winter day on 120v (20a), it takes at least 30 minutes before the battery warms enough to start charging. During that time I see 0 mph, then after bit 1mph.... until finally I see 6 or 7 mph. Late fall to early spring means you have to drive an ICE vehicle for trips to Minneapolis, MN since the nearest SC is Clearwater, 190 miles east of Fargo.
On the plus side, dual motor with snow tires rocks! SC are under construction now in Dickinson & Bismarck (west of Fargo), making travel to the west a lot easier, and coming soon to Fargo & Alexandria MN to make Minneapolis travel in the winter a possibility. Travel to Canada is also coming this fall with Grand Forks, ND and Pembina, ND.
