Some reported a 2019.32 release, so we can use this to capture any thoughts as it rolls out.... Teslafi not yet reporting this release, however...
You sure it wasn't a typo for the various 2019.23.x releases?
Those release notes mention keyfob update for "model S". Since this is the model 3 forum (not the model s or general software update forum), did you find notes somewhere that this update was for model 3?
On a side note, most of the time these threads turn into "I got it" or "I didnt, why didnt I?!?!??!" and people quoting teslafi stats as if everyone who would be getting the update would be on teslafi.
All that is fine of course, but they normally start with "I found XXX installs on teslafi". Why jump the gun in this case?
I think they switched to the v2 key fobs in June 2018. Before the switch, they were using the 40 bit key fobs which were are easier to hack.Anyone know how to confirm if you have a v2 key fob?
Tesla says that Model X key fobs are less subject to those attacks since they already had “robust cryptography” and Model S vehicles since June 2018 also come with the same key fobs.
Just got push for update. It’s in process now so I can only assume it is 2019.32. Will report back what got installed.
Software Update
The status bar will now indicate when there is a software update available to be downloaded. Tapping the icon will take you directly to Controls > Software for additional details regarding the update.
New Language Support
You can now select Norwegian as your language. To update your language setting, tap Controls > Display and select the desired option from the Language drop down menu.
This release contains minor improvements and bug fixes.
28.3 still has black rear camera appear every now and then.
I guess it’s forever to stay or fixed on 32.x?
Never had any rear camera issues with 24.4.
