oops 2019.40.1.1
Now downloading on my 2018 MS100D
MCU2!
MCU2!
Installing now via app. No access to my car. Can you please post release notes ASAP?Same here. Just got the notification.. excited.
My 2018 MS100D (MCU2) is scheduled for the 3.0 FSD computer upgrade next week. Perhaps, it was initiated by a SC technician. Lately they have been updating prior to appointments. The holiday might explain why it was done so far in advance of my appointment.Curious timing for a new version. Companies avoid new versions just before major holidays .... because of scant support.
Psh it wouldn’t be very Silicon Valley if engineering isn’t working through the holiday.Curious timing for a new version. Companies avoid new versions just before major holidays .... because of scant support.
My impressions: Lane changes are definitely more assertive now, but there's still a pause of a couple seconds and about 4-5 blinks before it starts the maneuver. Once it starts it's much quicker and more decisive than before, and merges into much tighter quarters. I haven't had an aborted lane change in my drive this morning (and there's moderate traffic and one instance that I'm sure would have aborted before due to a car merging in from the other side a few car lengths behind).
And although the release notes imply it's just the NoA initiated changes that are affected, the manual ones are amazing now. As soon as you tap the stalk it blinks and moves immediately. Not sure if thead Max setting affects that too, or just how jumpy NoA is at deciding to pass someone as the wording suggests. I did turn it up a notch to Mad Max just this morning to test.
Hopefully this also helps the wipers stop operating at full speed, continuously at startup without intervention!
I've seen that happen before, perhaps they do limited releases to get the sample size they need to test out the updated software for bugs?Had a notification at 11:46pm last night. When I woke up there was no update pending. Must’ve been pulled between 11:46pm and 7:45am Only 1 showing today on Teslafi so mine must’ve been pulled before install
