I’ve noticed additional drain. I selected sentry mode from the screen in the vehicle and haven’t activated it within the app yet. It seems as if it’s acting like sentry mode is somehow active even though I haven’t selected it within the app. No climate control enabled. Or maybe it’s something else?
I don't think there's any need to also activate it within the app. If you turned it on in the car it will be on.I’ve noticed additional drain. I selected sentry mode from the screen in the vehicle and haven’t activated it within the app yet. It seems as if it’s acting like sentry mode is somehow active even though I haven’t selected it within the app. No climate control enabled. Or maybe it’s something else?
Every few hours it starts charging again to top off.
Not sure about that. I thought the sentry mode button on the car screen allows you to select that feature and if you wanted to activate it you have to use the app each time you park.I don't think there's any need to also activate it within the app. If you turned it on in the car it will be on.
I thought the story was you had to choose either one each time you parked. Have you checked if the car setting is permenently on? I’ll bet it’s not.Not sure about that. I thought the sentry mode button on the car screen allows you to select that feature and if you wanted to activate it you have to use the app each time you park.
Oh, ok. So it’s not the same as ie; selecting summon in the car and it’s always on so you can use it with the app or keyfob. Didn’t realize that you can choose to select it within the car or the app and it’s the same thing.I thought the story was you had to choose either one each time you parked. Have you checked if the car setting is permenently on? I’ll bet it’s not.
