2019.8.3 Stronger Regen Over 30 MPH
astrowunder
461
429
Wisconsin
Here's the sequence of events yesterday with regard to driving my car.
< 3:00pm - Car parked in unheated garage attached to house, plugged in to charge
3:00pm to 4:30pm - Ran a few errands, driving distance about 20 miles, temperature 59 degrees, minimal regen over 30 MPH
4:30pm to 8:30pm - Car in garage, not plugged in to charge, 2019.8.3 update installed about 6:00pm
8:30pm to 8:50pm - Drove 15 miles, temperature 48 degrees, immediately noticed much stronger regen over 30 MPH
8:50pm to 9:10pm - Parked in outdoor parking lot, temperature 47 degrees
9:10pm to 9:30pm - Drove 15 miles back home, temperature 45 degrees, stronger regen still apparent
So when do you think the battery was likely to be cooler or warmer in my travels yesterday? Also, my car has always displayed a regen limited message when it is cold, and the regen below 30 MPH has been much less when this occurred.
This is stronger data indicating there is an improvement. If only Tesla would provide more detailed release notes so we could be sure.
GregD60
346
337
Colorado
Yes, the release notes mentioned the 5% power increase, but said nothing regarding any change to regen behavior. I was surprised by the change immediately after installing the upgrade.
Silicon Desert
3,059
2,809
Sparks Nevada / GF 1
My car is a November 2018 build. The difference is not subtle, and it is not my imagination. What is wrong with you people that you need to be insulting?
Gee, I didn't get that impression at all. I thought the commenter was trying to be helpful. Different folks, different impression I guess. I was also thinking it is the weather or your imagination and that is not intended to be rude at all. :)
  • Disagree
Reactions: voip-ninja
jamnmon66
572
406
Brighton, CO
I suspect that it's a fix for the winter tire issue but it'd be cool if it's more than that. I had a dramatic loss of regen when I went to winter tires last fall. An update fixed it maybe around December or so (sorry, don't remember the version). I'm not sure if it's as strong as it was on the stock tires but it's much better. I'm still on 5.15 & I'll report back if I notice anything on the next update. Rwd LR.
Runt8
1,986
2,371
Colorado
I have a LR AWD that I picked up at the end of September. Currently I don't get very strong regen above 30, regardless of the battery temperature (now that it's getting up in the 60s and higher I'm not seeing limited regen as much). I'm still on 2019.5.15. I will post back here if I get the 8.3 update.
Reactions: dusdev
datoda
178
116
NH
I think it makes perfect sense to have stronger regen when you get the performance boost. The extra electricity needed for the boost has to come from some source without reducing the range. Regen is that source.
I also got 8.3 last night on my LR AWD. I didn't notice stronger regen nor higher performance when I drove it this morning. But the drive felt subtly different in ways that I can't quite put my finger on.
BTW, I lost my bass after 8.3 update. :(
Silicon Desert
3,059
2,809
Help me out a bit more with that statement. Being an electronic design engineer for 40 years, I am having a hard time with that line of thinking. We are talking about 2 different things if I understand you correctly. ;)
EVnut
DARΞLL
Mar 24, 2009
1,587
1,217
Davis, CA
Just installed the 2019.8.3 upgrade today, and immediately noticed stronger regen at speeds over 30 MPH. I have a LR AWD (non-performance), and in all the prior versions, the regen at speeds over 30 MPH was very mild, and then it would get much stronger as the speed decreased below 30 MPH. The regen is now significantly stronger, and seems more linear in response to the throttle and as the car gets to sub 30 MPH. I like this much better. Anyone else?
This is great news. Thanks for sharing. I have the same configuration, and have *always* wanted more regen.
Has anybody ever figured out if the regen is all on the rear motor in the AWD cars, or do we benefit from some front wheel braking as well?
BrakeDome
105
73
Washington
I’d have to agree overall with the OP on this statement. Im not sure I’d say significantly stronger, but I do feel the regen is more pronounced than before. And it does seem more linear as well. I’m wondering if it’s somehow a positive “side effect” of whatever software tweaks Tesla did to include the 5% power increase.
Ironically, I don’t really notice the power increase at all, but I am enjoying the more linear regen :p
I also have a non-performance AWD, got my 8.3 update yesterday, previously was on 5.15. Stock all-seasons.
Reactions: Scott7 and dusdev
EVnut
DARΞLL
Mar 24, 2009
1,587
1,217
Davis, CA
This makes no sense. A "stronger" regen is not going to offset the power needs of a "performance boost." It would be awesome if it worked that way. Let's go for max regen so we can get 400 miles of range!
Hint: Regen is not a "source" of energy.
Trips
"Boring bonehead questions are not cool. Next?"
Sep 22, 2015
1,214
1,402
Omaha, NE
Hopefully it's more linear. Here is what mine on 2019.5.15 seems like.
0-8mph = none
9-20mph = high
21-30mph = medium high
30+mph = medium/medium low
dusdev
357
389
Ontario
0-8mph = none
9-20mph = high
Sounds about right. I wish that the vehicle would be able to bring the car to a complete stop (say, with creep off) in that lowest range. Even if at the bottom end it lightly applies the friction brakes. It's always a bit of a game for me to coast to the required stop and minimize friction braking manually. If the deceleration curse was more linear it would be an easier task.
Reactions: Scott7
IROAR
80
98
Arizona
I too have noticed with the new version stronger regeneration at higher speeds. My question: Does the brake light go on when you take your foot off the accelerator given you slow down as quickly as applying the brakes? Sorry to partially hijack the thread.
ALSETJC
283
253
Toronto
It was -1 C this morning and I received the update.I had full regen when I left my house. Usually it's 1/2 to 3/4 of Regen due to the cold. Did not charge and only had 45% battery . Will keep monitoring.
RFernatt
Solar/EV Owner/Enthusiast
Oct 13, 2016
645
3,363
Eastern Panhandle, West Virginia
I think stronger regen makes logical sense when thinking about the new charging rates supported by the Model 3. If the allowable charge rate and curve has been increased for v3 SCs and enhanced v2 SCs, it makes sense that regen max output can also increase if the BMS is allowing greater charge and at higher states of charge. The power is just coming from the regen instead of an SC.
dusdev
357
389
Ontario
Yes the brake light turns on when the car is decelerating (both from regen braking and friction braking). The car graphic on the display also shows the brake lights coming on.
Mo City
1,852
11,167
near Houston
Yes they do. You can see when the brake lights come on by viewing the car on the monitor.
Runt8
1,986
2,371
Colorado
With the caveat that they only turn on when you are decelerating “fast enough.”
Reactions: BrakeDome
Big Earl
bnkwupt
Jul 12, 2017
4,985
8,938
Springfield, VA
Not necessarily. Range is based on the EPA test cycle, so how much power the car has available won't affect that, since the test cycle never uses full power.
It's possible that Tesla relaxed the impact of cold battery temperature on charging (regen) speeds, allowing higher charging speeds and thus regen when the battery is cool (40s and 50s).
I got 8.3 this morning. I'll take it for a spin this evening and see what's different..
Reactions: davedavedave
