Updating the spreadsheet with the latest data from Model Y. This is just for reference since there is not a lot of traffic in the Model Y forums. We should not devolve this thread into discussions about the Model Y. I will link to threads
here,
here: Model Y More Efficient Than Model 3?!, and here:
Updated CARB certificate for Model Y Performance for those discussions.
The Model Y data in red is close, but not exact (specifically, the UDDS miles do not align with any result published so far - current CARB data is 447.17mi). All the other data in green text for Model Y is directly from the EPA datafile.
As usual, except for Model Y, the data in the orange boxes is directly pulled from the EPA datafile. Everything else is calculated by the spreadsheet, and aligns with published results AFAIK.
There is a lot of talk about the Model Y being just as efficient as Model 3 today. You can see from this spreadsheet that the raw dyno data suggests that is very likely not the case. It appears to be far worse on the freeway, for sure, as one would expect. It is the magical scalar of 0.756 that makes this magic possible. I do not know what the motivation is for that high of a scalar or whether it is legitimate at any time. The range optimism field is my measure of how easy it is to make the rated range. The more negative, the harder it is. It's the ratio of (the difference of the rated DC Wh/mi efficiency and the true DC efficiency) to (the rated DC efficiency). It seems to me it will be very difficult to get rated range in a Performance Model Y.
EPA Datafile, updated frequently:
Download Fuel Economy Data
