I usually charge at night due to TOU rates. Yesterday I charged in the middle of the day so I could monitor the car and the kWH meter.
Charge Screen : 30 mph, 236V, 32A
kWH meter : 239V, 31.1A, 25kWH (meter reads in whole kWH, no decimal)
Charge time : 3.4 hours
Range miles added : 103 miles
AC Charge Constant : 252 X 103 = 25,956 wh = 26 kwh
Charge Screen : 236V X 32A X 3.4 hours = 25,677wh = 26 kWH
kWH meter amp error = 31.1/32 = 0.969 = 3.1% error
kWH error = 25/26 = 0.962 = 3.8% (Rounding can introduce up to 0.9 error. 0.5 to 1.4 = 1)
I wanted to verify meter error so I connected a Fluke 87 meter and the kWH meter to a water heater circuit.
Fluke 87 = 14.0A
kWH meter = 13.58A
Error = 13.58/14 = 0.97 = 3%.
So from what I have calculated the kWH error is between 3-4%. The lack of a decimal in the kWH reading makes it hard to be exact.
Cool. Everything makes sense. Note your meter, aside from reading a little low, is measuring cable losses too.
Looking at my table again for efficiency, it is 88.7% for the LR RWD. If not charging to 100% it might be a little higher due to lack of taper. Let’s call it 89%. (So more like 251Wh (AC) per rated mile added.)
AC kWh: 236V*32A*3.4hr = 25.68kWh
DC kWh to battery (expected): 0.89*25.68kWh = 22.85kWh
Actual DC kWh: 103rmi*223Wh/rmi = 22.97kWh.
So that efficiency checks out within 0.5%.
(For clarity, note the charging screen in the car uses the charging constant, so will display 103rmi*234Wh/rmi = 24kWh for this event - that is spurious, it does not represent actual energy added to the battery.)
Your meter (assuming its voltage is correct) measured 3V*31.1A*3.4hr = 0.317kWh of loss in your cable.
But anyway it does appear your meter reads about 3% lower than it should - it reads 25.3kWh, of which 0.3kWh is cable loss, so 25kWh vs. 25.7kWh which is 2.8% off, by the current ratio.
Of course the car amperes may be off slightly - the Fluke experiment suggests the kWH meter is truly 3% low (if Fluke is perfect), suggesting the car might be drawing very slightly more (0.2%) than 32A when it displays 32A and your kWH meter shows 31.1A.
Anyway all this charging data checks out and is what is expected, within the bounds of error of the measurement methods.
Another clear confirmation that charging efficiency is right around 88.5-90% at 32A (7.7kW) in warm weather. This fact can be used to assess the accuracy of your rated miles display in warm weather - take the AC energy you add in on a big charge and multiply by 0.89 to figure out your kWh actually available due to that charge...
