2020.24.6.4 Missing rear camera on Sentry recordings
sevenout
169
161
Orangevale, CA
I have an Aug 2017 MS. I did the Infotainment upgrade and FSD last month and now have Sentry recordings and TeslaCam. Prior to getting the most recent 2020.24.6.4 update the other day, I’ve always had front, rear and both side repeater video recordings for Sentry events. Drove for the first time today after installing 2020.24.6.4 and now the rear camera feed is missing from the Sentry events and Dashcam recordings. Anyone else seeing this?
croman
4,912
7,143
Chicago, IL
My rear feed is still visible after the update on prior recordings. I haven't driven so I haven't tested with new recordings. @drklain also reported this curious issue but they just received their MCU2 upgrade. I will test this issue out when driving. My rear cam recording had been working great.
sevenout
169
161
Orangevale, CA
My rear feed is still visible after the update on prior recordings. I haven't driven so I haven't tested with new recordings. @drklain also reported this curious issue but they just received their MCU2 upgrade. I will test this issue out when driving. My rear cam recording had been working great.View attachment 560358
Unfortunately I didn’t have any old recordings to look at. From before the update.
Tested it and my rear camera is still present on new recordings with the in car viewer even on the latest firmware (2020.24.6.4).
Was your car upgraded from MCU1?
I have the same issue. No rear camera recording. I tried reformatting USB and rebooting the car. No luck. Any ideas?
As @croman mentioned above, another user has this issue and was upgraded from MCU1. This is my situation as well. Maybe only those that were upgraded are having this problem.
croman
4,912
7,143
Chicago, IL
Looks like you were upgraded from the look of your camera feeds. Well that shoots down that theory.
Yes, I was upgraded from mcu1 Ap2 to mcu2 fsd on June 22. I'm not sure what happened to your car. Sorry, I think it might have to do with the wiring harness they use for the Ap2 cars.
I found some quirks with my touch control. MCU will work but can only control with steering wheel. Latest firmware seems to have fixed it.
Maybe gremlins are a side effect of MCU upgrade?
negotiator50
9
5
Michigan
I have a 2018 MX. Upgrade was from MCU 2 or 2.5 I believe.
sevenout
169
161
Orangevale, CA
I may call Tesla technical support and have them pull the logs and see if they can see anything.
