2020 Model 3 switched 12V source already used *need alternative*
Discussion in 'Model 3: Interior & Exterior' started by vogz, Jan 2, 2020.
  1. vogz
    vogz Member
    Batavia, IL
    Took delivery of my 2020 P3D+ last week. I've been slowly doing some work on it and ran into a snag attempting to hardwire my radar detector. According to threads on here, and the YouTube channel Ingineerix there is an unused 12V switched power source behind the drivers side kick panel. Apparently that is no longer the case as that source in my new Model 3 is being used by something else. I don't have enough dexterity to get tools up there to tap into the red wire and don't know if I want to not knowing what it powers.
    Any other ideas?? I'm already worried about a speeding ticket since I quickly don't realize how fast I'm going in this thing.
    Thanks!
    Obligatory pic of the new ride. Loving it other that this issue!!!
    • Disagree x 1
  2. todd2fst4u
    todd2fst4u Member
    Menlo Park
    Follow the wire down and tap it in the driver footwell area. That’s what I am doing to power my valentine v1.
  3. vogz
    vogz Member
    Batavia, IL
    Do you have any pictures of where the wire runs exactly? I wasn't able to follow it when I was in there yesterday.
  4. Timbo2
    Timbo2 Member
    If I remember correctly it is for a trailer hitch. My guess is that it now goes to a harness that is now pre-wired on your car.
    My bet is you can pull it out with no issues if you don't use a hitch. However, to confirm you'd have to remove the the panel under the rear bumper and see if there is wiring in place that is no longer energized with the connector removed.
  5. todd2fst4u
    todd2fst4u Member
    Menlo Park
    0657086F-5563-4DC6-A48C-E92BDFA9D929.jpeg D71F8607-EC26-4793-92FB-47E0F1B22BF0.jpeg
    It runs down towards the floor from where you took a photo of it. It’s mixed in with a bunch of other wires heading the same direction.
  6. vogz
    vogz Member
    Batavia, IL
    good info! I’ll check that out too. Definitely won’t be running a hitch.
    thank for the pics, that’s perfect!
  7. vogz
    vogz Member
    Batavia, IL
    Install is done! Thanks todd2fst4u! I definitely had to dig in that harness to find the wire, but it’s all working now.
  8. baba
    baba Member
    Sweden
    @vogz
    Did you remove the hitch wire?
    Is it constant power or does it switch off when the car is off?
  9. vogz
    vogz Member
    Batavia, IL
    I didn't remove it, I just tapped into that wire further down in the kick panel area for easier access. It's switched 12V.
  10. baba
    baba Member
    Sweden
    After the update of 2020.16.2 1 my lights are still on after i close my car.
    Some one else that has this problem?
  11. Idkorcare
    Idkorcare Member
    Atlanta
    There is a post on i think the main page “12v switched” that a few were discussing it on but basically same issue and basically makes the power now the same as the penthouse and power outlets best i can tell so its only off when car is asleep
  12. Kenneths031174
    Kenneths031174 New Member
    Hk
    todd2fst4u
    is the 12v acc turn on when press the break?and turn off when the driver leave the car?
  13. charlieaf92
    charlieaf92 Member
    cincinnati
    Do you remember what size splicer/tap you used by any chance?
  14. vogz
    vogz Member
    Batavia, IL
    I don’t remember the size of the tap, but the wire looks to be 12 AWG, so a tap compatible with 12 AWG wires should work.
  15. charlieaf92
    charlieaf92 Member
    cincinnati
    Great, thank you!
