2020 Model SP: metallic coating on windshield?
craigger
49
85
San Diego
Hi all -
I just got a 2020 Model S Performance and I'm looking for radar detector solutions. In my manual, it states that there is a cutout to the metallic windshield to the right of the rear-view mirror:
1591541192479-png.34245
Under really close inspection, I don't see any cutout (nor the black dots that they used to mark this area with). Also, I don't see the "purple hue" looking at this windshield from any angle.
Question: does anyone know if they finally got rid of the metallic coating or if it's all coated now? I'm really hoping the former so I some flexibility on where to put the radar detector. I know a built-in solution (e.g. Escort Max Ci 360) would be a better solution but not worth it at 10X the price of a windshield option.
Thanks,
-craigger.
croman
4,626
6,551
Chicago, IL
I think it is coated all over and I just put my ipass transponder below the rearview mirror. I don't think the cutout thing has been present since refresh in 2016.
Reactions: craigger
craigger
49
85
San Diego
I have a Valentine1 Gen2 coming in on Monday (that I'm really hoping I don't have to return). I plan on doing some experiments with different parts of the windshield and with no windshield using my local grocery store door sensor as my radar source and I'll post results here.
craigger
49
85
San Diego
OK - did a quasi-scientific test. Went to a parking lot where there were several door opener radar sources present. I pointed my car at one and did the following.
First, put the radar detector out the window and got a reading:
Took a reading through the driver's side windshield (with window rolled up):
Then, took a reading in the "non-metallic zone" as defined in the owner's manual:
Then, took another reading outside the window to make sure it didn't change too much:
Readings were fluctuating slightly, but these are pretty representative.
Also, I took a close look to see if I could detect any metallic film or "cut-out" area:
I saw nothing other than clear windshield. Finally, I took a look at the windshield "bug":
If there were a metallic film, I'd expect to see something like "LAMINATED AS1" (I don't know if this is always true).
My conclusion - no metallic film on the 2020 Model S Performance so you are free to mount a radar detector anywhere on the windshield.
-craigger.
whitex
6,379
7,546
Seattle area, WA
-craigger.
I have a picture in this post of what the coating used to look like in the old days (from my 2015 MS, which doesn't even have a cut out as pictured in the manual, my old 2013MS did) - you can only see coating from the outside on a sunny day. That circular cut out area is for rain/light sensor in AP1 cars. That said, given your radar test results, you have no coating. I've done this same test with coating and the radar strength is cut by as much as 80%. Because of this, I ended up going with Stinger VIP instead of Valentine One - way more expensive solution and took me quiet a few hours to install, but since I was already doing the install I put in laser jamming at the same time (with V1, laser warning is just to let you know you've been clocked and probably about to get a ticket). Radar direction indicator on Valentine One works way smoother, but Stinger does the job.
Reactions: craigger
craigger
49
85
San Diego
Thanks for the info and photo. Here's the photo of my windshield from the outside:
Once again - more confirmation that they removed the metallic coating.
That Stinger VIP system looks insane. I'll have to look at laser jamming solutions for my car.
-craigger.
Mar 1, 2018
119
142
San Marcos, CA
Good info in this thread. Thanks for doing that test.
The newer ones are still laminated (even those without the metal layer), so that probably won't help. On the other hand, unlike earlier windshields, yours has the actual Tesla part number printed on it, which is helpful for reference: 1061987-01-H. At minimum, we can tell that this revision won't give us any trouble.
If someone with a nosecone Model S finds that they've got the metallic film without a cutout, another option is to put the radar detector behind the nosecone, as I describe in this thread: https://teslamotorsclub.com/tmc/threads/detailed-how-to-install-a-valentine-one-radar-detector-behind-the-nosecone-of-a-model-s.171486/ For the reasons described at the start of that post, if you don't have metallic on the windshield, you're better off putting the detector behind the windshield like usual.
Reactions: craigger
craigger
49
85
San Diego
Wow - nice job on the nosecone install. That must have been a lot of work - I'm really glad I can just use a windshield mount.
provenkick
New Member
Sep 12, 2020
2
0
Flower Mound, TX
I'm expecting delivery of a 2020 Model S LR this month and am hopeful that the metallic coating is not an issue. This is good information and will perform the same test as craigger. I've been driving with an Escort for so long, I don't think I could handle the withdrawals if I couldn't keep using it!
