2021 model Y scan my Tesla battery size
Discussion in 'Model Y: Battery & Charging' started by coconutboy84, Dec 6, 2020.
  1. coconutboy84
    coconutboy84 Member
    Ontario
    Hey guys. Someone was asking for this the other day so just thought I would post my findings. I have a 2021 model y long range. Just delivered two days ago. I installed scan my Tesla and it’s reporting 77.8kwh when new and 77kwh current capacity. So if it is the 82kwh, right now the bms is hiding it....or it’s the old cells. Just FYI!
    • Informative x 9
  2. Koolio46
    Koolio46 Member
    Boston, MA
    Very interesting...
  3. kadify
    kadify Member
    colorado
    Maybe a dumb question, but isn't it supposed to only have 75kWh? So the fact it has more means it is a bigger size? I'm not sure but wouldn't some percentage of the battery be reserved so even if the car goes to 0% there is technically still power?
  4. akballow
    akballow Member
    San Jose, CA
    Would be nice xmas surprise
  5. DC2ACMY
    DC2ACMY Member
    Minnesota
    It could be the app, or something else? That said the Model Y had a 75 KWH battery of which 72.5 KWH is considered "useable". That's a roughly 5 KWH difference. If you take the 77 KWH and add 5 you would get to 82 KWH...coincidence? Fluke? Not sure but will be interesting to see.
  6. MY-Y
    MY-Y Member
    MD
    The yellow sticker under the frunk cover on mine says 74 kWh.
  7. coconutboy84
    coconutboy84 Member
    Ontario
    they removed that number on the new 2021's
  8. frankvb
    frankvb Supporting Member
    San Diego, CA
    #8 frankvb, Dec 7, 2020
    FWIW - ABRP reports my battery capacity as 76.9 kWh. 'old' 2020 Model Y AWD LR. No idea if that is accurate, or how it gets that data.
    It also reports 0% degradation.
  9. pt19713
    pt19713 Member
    Delaware
    It's 77.8 kWh. They report it as 75 but there's a "zero mile" buffer, so essentially the car has a reserve like you see in gas vehicles when the fuel light comes on.
  10. kadify
    kadify Member
    colorado
    Ah ok I thought I'd read it was set up that way. I thought it was hidden the way ICE vehicles have that hidden extra range after 0.
  11. lephantom
    lephantom New Member
    Pasadena
    I picked up my Y 3 days ago. VIN 84k. Charged from 52% to 92%. Calculated battery capacity of 81.75 kWh! 12BF8633-BFBA-4D3D-A55A-234AA76593B0.jpeg 9CF3EADB-A5F8-4DCC-A627-D1160CA9CBA3.jpeg
    • Informative x 3
  12. coconutboy84
    coconutboy84 Member
    Ontario
    I don’t think you’re taking into account charging losses.
  13. MY-Y
    MY-Y Member
    MD
    When I multiply my Wh/mi and range from the display and divide that by the percent charged, I consistently get 71.5 - 72 kWh. What are you all seeing from this calculation? (12xxx VIN, 5800 miles)
  14. lephantom
    Pasadena
    I know charging loss for AC to DC is somewhere around 8-10%. Not sure how much loss is for DC to DC. But I think it’s small if the wire gauge is low. I charged my Y on a DC 50kW charger.
    I use the same charger on my daughter’s Chevy Bolt and get about 58kWh which is correct for usable portion of the 60kWh battery. Now the Tesla could have been using some of that energy to cool the battery, but the fan didn’t turn on super high.
  15. IA_TESSIE
    IA_TESSIE Member
    IOWA
    They may be seeing different results because we are expecting a 82KWh battery in the 2021 Model Y "soon".
  16. BAven8068
    BAven8068 Member
    Chicago
    #16 BAven8068, Dec 8, 2020
    Is Teslafi an accurate way of determining this? Here are the stats from a recent charging session on my 2021 Y (VIN 70XXX).
    If I calculate that 44% added 33.63 kWh of usable capacity then I get 76.43 kWh of total usable capacity at 100% this seems to be more than the 72.5 kWh usable I thought the Y originally had, but I don't know if this is an accurate way of doing it or if I’m missing something.
    Edit: Going back and calculating off of prior charge sessions using this method and I get total usable battery amounts anywhere from 75-79 kWh.
  17. coconutboy84
    coconutboy84 Member
    Ontario
    Here is a video showing scan my Tesla. For anyone interested.
  18. pt19713
    pt19713 Member
    Delaware
    Yep, I have it in my Y. It's been a great tool learning how the battery pack warms up in colder temps, pre-conditioning, and all that good stuff.
  19. JustinA1
    JustinA1 Member
    San Francisco, CA
    I suspect at this point that the 2021 Model Ys being produced have the same 82 kWh pack that the refreshed Model 3 does, which in turn has a usable capacity somewhere around 78-79 kWh. I think we all get confused between the raw pack rating and the usable rating, and the difference seems to be about 5% in general. The previous pack appears to be 74 kWh with 71-72kWh usable.
    My big question at this point is whether Tesla has another efficiency software upgrade in the works for the Model Y or if this is where we stand for a while. When the pack change occurred, the Model 3 LR saw an approximately 10% boost in range (322 mi -> 353 mi), whereas the Model Y LR got an approximately 3% boost from a 9% pack size change (316 mi -> 325 mi). The Model 3's could be bigger because of the heat pump and whatever else was included in the refresh though.
    • Disagree x 1
  20. pt19713
    pt19713 Member
    Delaware
    No, the 2020 Model Y battery pack is 78 kWh with 75 usable. This has been discussed in several Y threads and a bunch of 3 threads.
