mbdionio
Thank you posting this info. Now I have the data to help me move forward with the order.
So what was the data that helped push you to order?Thank you posting this info. Now I have the data to help me move forward with the order.
This document suggests to me that only the performance 21 currently has the bigger battery. Note the “End-SOC” in the manufacturer comments of each test.
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=51237&flag=1
so from 100%SOC, the MY AWD consumed 77.7kWh + unseen battery buffer = ~80ish kWh battery
Yeah makes no sense that LR has more rear power when the P had the larger rear tires... all they did was shift the rear power to the front wheels which gives a closer to equal power delivery.As a quick aside, did anyone notice the difference in motor rated power between the front and rear motors in the LR AWD and the P? Funny seems like the rear AWD has more power. But front is lower, by a bit.
It also shows Tesla sandbagging the actual motor power numbers, which most of us already know, especially on the MYP.
I measured 162 kW from the front motor, 218 kW from the rear motor after the acceleration boost (LR AWD Y). 509 hp (and 401 lb-ft torque) if you do the conversion. Sorry no numbers stock.
Scan My Tesla app, pulling straight from the CAN bus.How did you measure the power output?
Yes, on the LR AWD Y, the AB wakes up the front motor. It's similar to how the AB on the LR AWD 3 works.The amazing document that was shared shows on page 29 that the front motor for the LR-AWD is 69kW and rear motor 201kW. So AB really awakens/unlocks the front motor?
Also, agree with others, why is the LR-AWD rear motor more powerful than Performance? How bizarre, or as mentioned above sandbagging which isn't unique to Tesla, other MFG's sandbag performance output. I can't think of any EV MFG's but BMW does this frequently with their ICE vehicles.
That does appear true however in the highway portion of the test the performance is more efficient. This is backed up by some driving tests. Around town I am not that concerned about range. When I am on the highway taking trips it becomes critical.If that pdf is correct then the long range still has more range than the P, with less battery
Seems to be a lot of non-definitive evidence supporting the 82kwh battery in the new MY
This is really interesting and I’m surprised it hasn’t received more attention.
If there is a way to check the battery capacity at the time of inspection,
