2021 model Y scan my Tesla battery size
lozza
148
95
Bay Area, CA
Battery capacity in Wh = Projected Range * Recent Avg Efficiency / SoC % (sorry quote not working for me)
Could you walk through which units you are using here? As I don't think I'm calculating my own car correctly. Will be interesting to see as I have confirmed (by Tesla) 8% loss, so should be at about 69Kwh for my 2018 P3D-
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
8,973
10,695
San Diego
For example, my car says, at 80% SoC, with recent average efficiency of 310Wh/mi (for the 5-mile setting, but doesn't matter), gives a projected range of 180 miles. So:
180 mi * 310Wh/mi / 0.8 = 70kWh.
lozza
148
95
Bay Area, CA
For example, my car says, at 80% SoC, with recent average efficiency of 310Wh/mi (for the 5 mile setting, but doesn't matter), gives a projected range of 180 miles. So:
Thanks for clarifying. Interesting. My calculation works out at 74Kwh... Which is confusing as I'm confirmed 8% loss at my stage (by Tesla, at ~30K miles)
(224 * 264 / 0.8) = 73,920
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
Just make sure you don't have "instantaneous" set on the energy screen. Has to be the average setting (easy to tell but if you're not paying attention you could pick the wrong one)! You can also do 5/15/30 miles and redo the calculation for each (they'll all be about the same).
That result would project to 301 rated miles at 100% (for your vehicle type). No idea what you're actually seeing projected by the Tesla app when you pull the slider to 100% (that's a good way to crosscheck the result - you need to set Display => Energy Display to Distance mode, though, in the car).
Anyway this is a Model Y thread...so I'll try to steer back towards Model Y and SMT here. Though since the batteries are basically the same, it's mostly applicable except for the miles numbers.
Venom
298
158
Chicago, IL
The new related threads feature is awesome.
Here is the link to the post in this thread though:
The new quote feature, however, not so good - I have no idea where it is getting that text from. It’s from a post somewhere on this thread, just not that one!
Additional caveat on this method is that of course capacity lockouts can be hidden by Tesla when using this method. SMT might show such a lockout by showing FPWN value higher than Nominal Full Pack. There are several other scenarios as well. But as far as utility goes, the method is great - it tells you how much available energy your BMS thinks you have (with a full pack) before vehicle shut down.
Just picked up my MYP. This is what the home display looks like. Haven’t driven it yet. Calculated 80.5kwh. Does that mean I have the upgraded battery?
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
Yep. That's exactly what we would expect. Most people see about 80.5-80.8kWh or so on SMT when the car is new. And SMT says 82.1kWh for "Full Pack When New." (This is an atypical discrepancy which applies to all 2021 Performance Model 3/Y and the reason is unknown.)
If you had got an AWD, you would have calculated about 77.8kWh (assuming the rumors of a larger battery remain unfounded...it's very easy to document a larger battery, so until we have firm evidence, the AWD can be safely assumed to have the old Panasonic cells).
These values are all to a completely dead battery, using all the buffer. 95.5% of this energy is available above 0%/0rmi.
North75
595
723
MA
I just checked mine and have the following numbers:
202mi*252Wh/mi / 78% = 65 kWh.
This is for a 2018 Model 3 LR RWD with 23,800 miles.
Sounds pretty crappy. The projected 100% range as shown on the phone app is 276mi.
Would this be in the range of normal degradation, or should I be contacting service to check for an issue?
Has anyone else had experience with similar numbers?
(Just realized this is the model Y thread. Is there a similar thread for model 3?)
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
This is for a 2018 LR RWD with 23,800 miles.
It's within the range of normal degradation; yes, 276 mi at 234Wh/mi for that vehicle is 64.6kWh, so your calculation checks out.
The degree of degradation for you and what "qualifies" is a little tricky for the RWD - initial 2018 RWD shipped with ~72.5kWh (310) and were later increased to 76kWh (325), which may have actually been 77.8kWh (hard to know, I don't know what SMT gives for "Full Pack When New" value for these packs).
So it's either 10.5% capacity loss, or as much as 16.5%, depending on what the actual initial capacity value was.
Either way, well within the allowed capacity loss (of course this is a generally worse result than most people). I'd keep an eye on it and look for other symptoms before contacting service - if this were the only issue, there's nothing they would do.
I'd expect your range to not change too quickly from this point if your pack is aging normally.
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
Oops. Didn't pay attention to which thread this was, just saw the notification. Batteries are very similar though so the story is the same on Model Y for the most part:
Model 3:
North75
595
723
MA
Thanks for the quick reply. I'm reasonably confident I have a 72.5 kWh (310) pack. My car was a June 2018 delivery.
I never saw any range change when others were reporting increases to 322/325 via software changes.
So probably not great... but could be worse:rolleyes:
