2021 Model Y Sideview Mirrors Limited Adjustability
Discussion in 'Model Y' started by RedTikki, Dec 13, 2020.
  1. akiss13
    akiss13 New Member
    Jacksonville, FL
    Amazing and practical solution, thanks! I logged the issue right after delivery and my MY was in the shop for 2 days replacing the rearview mirror. Picked it up yesterday and the problem wasn't fixed (not surprising considering the solution), but also it now vibrates when I drive. So the image in the mirror is blurry, which makes the issue worse since their "fix".
    Service tech is coming out Tuesday and I will show him this thread, but also now need to figure out the vibration issue.
    Moral of this story is to probably just take the fix into your own hands.
  2. mbdionio
    mbdionio Member
    Austin, TX
    thank you for this solution!
  3. Impaler
    Impaler '20 MY LR Black/Black, 20" induction w/FSD
    Similar issue. I've always used the rule to put my face against the driver's window and move the mirror until I can just see a tiny bit of the side of the car. Sitting normally you won't see anything. It won't go far enough out to do that for me.
  4. everydaychris
    everydaychris Member
    Can you re upload? Photos aren’t there
  5. BBG523
    BBG523 Member
    Chicago
  6. 2101Guy
    2101Guy Active Member
    one word. Rushing.
  7. WADan
    WADan Member
    Bellevue WA
    So the Mobile Service came, and he popped open the mirror for me. I had to perform the surgery myself, and it worked. He also confirmed that my mirror is heated, but not auto dimming. He also confirmed I have pedestrian speaker. I am a happy camper now!
    He also said the best way to get Tesla to fix this design is to send Elon a message through Twitter. I don’t have a Twitter account (and not interested in having one), so it would be great if anyone else anyone would do the honor! Thanks!
  8. SirPaon
    SirPaon Member
    Chicago
    All -
    Going to embark on this fix tomorrow AM. As I have not messed with the MY mirrors before do the actual mirror parts just pop right off if I follow the directions and put my fingers back there and pull??
    Just confirming there is not some little thing I need to move to release them.
    Thanks for the awesome fix!
  9. jeffbco
    jeffbco Member
    Austin, TX
    The mirror doesn't come off easy - takes a good strong steady pull but no tools needed and nothing to release. Try not to put all the pressure on the edges.
  10. Pianewman
    Pianewman Member
    Fort Worth
    SirPaon: I understand your caution. Plastic clips can break.
    I'm going to study the photo of the back of the mirror. This shows WHERE the clips are, and will give me some idea of how to pull.
    I'll let you know how it goes!!!!
  11. Pianewman
    Pianewman Member
    Fort Worth
    Just did this mod. Super easy. Yes, you need to pull firmly on the mirror, and when it pops off, it...doesn't...sound...good!!!
    Tabs are very easy to break off. I used my fingertips. I lined up the mirror tabs, pressed mirror back on,...DONE!
    (FYI: I asked the most knowledgeable service guy at my SC about this. He says he's not heard anything about it!!!)
    (FYI: The production date on the back of the mirror was 11/15/2020, so it was new.)
  12. threeputts
    threeputts Member
    Minnesota
    Mobile service fixed mine today when they came out to install the homelink module (which works great btw). I had mentioned it in my service appointment request.
  13. X-Chris
    X-Chris Member
    VA
    Thanks for this, I did it on my car and now can cover my blind spot. Makes a big difference!
    Two additional notes:
    1. In my case, I had to clip a 3rd tab - the one on the lower left. I circled it in green in a copy of Blingeorkl's photo, see below.
    2. When I popped off the mirror, one of the wires disconnected. I almost didn't notice this. The wire in question is circled in Blue. To reconnect it, slide the connector over the corresponding pin on the back of the mirror.
  14. wraithfive
    wraithfive Member
    TN
    #54 wraithfive, Jan 7, 2021
    Update. Mobile service came out today and fixed mine. A new mirror assembly had been ordered but I don't think they used it. The dirt on the assembly seems like what I already had there lol. I didn't get to talk to them unfortunately. They were here, fixed it, and gone, before I ever noticed the message from the app on my phone. But when I went out to check the mirror is has the full range of motion I expect now.
    EDIT: I just looked that the invoice for the service (it was free but there is still an invoice.) The notes state "Adjusted drivers mirror per toolbox article #3114200". So for anyone having issues getting service to fix it giving them that to reference might help.
  15. ToutSuite
    ToutSuite Member
    Los Angeles
    This definitely helps, thanks! Mobile tech is out right now and didn't know much about the issue, but did say his manager had added a note to the service request. When he looked it up, he found the same article. I took a brief look at it and it basically says they are now authorized to trim the bump stops behind the mirror. He's doing so now.
