2021 MS LR+ rattling sound upon hard acceleration
Cheburashka
2,032
2,301
Los Gatos, CA
Same exact shudder I have experienced on EVERY dual motor Tesla I have driven. Our 2018 X has it. The 2016 one had it. Been in at least 8 loaner cars and ALL (some 75D, some 100D) had it.
It's interesting that it only happens with the air suspension. I don't think anyone with coils (when that was still an option) has experienced the shudder.
TSLA Pilot
1,644
2,272
United States
Does anyone have a mid-2019 MS Perf Raven (i.e. the early Ravens) with this issue?
Fort Worth SC reports that "I already have the -B half-shafts," so no replacement while they await the arrival of the -C half-shafts . . . ."
What has me confused is that others with early Ravens have had theirs replaced with the -B's and the problem was solved, thus having me wonder when that part was introduced on the assembly line--may have to jack it up and check myself.
Any inputs appreciated.
aerodyne
1,933
1,345
Los Angeles
You will benefit from taking the hands on approach.
First, if you have not already, peruse the applicable SB. The problem is the clevis, worn halfshafts are the result of improper shimming of same.
There is no excuse for the SvC not to be following the SB to the letter.
I don't have this problem since I have an older car that stays in Chill Mode, but there is no reason you should have to live with this...
TSLA Pilot
1,644
2,272
United States
AFAIK, that SB doesn't apply to Ravens, although it is remarkably unclear on that topic--I don't even think it provides a VIN range?
Also, my production date is July, 2019, and the date on the SB posted earlier is May 28, 2019. As a stockholder and owner, I sincerely expect Tesla to NOT be producing cars on the assembly line in need of an SB the minute they roll out the factory door--that's just too stupid.
Just thinking out loud . . . have to get the car back and crawl under it to see what my half-shaft part numbers are. (I wonder if that clevis has an easily visible part number?)
The bigger question: Why am I having to do all this on a six-figure car that's under warranty, with under 5k miles?
Answer: lack of sufficient durability testing and "not great" customer service at Tesla.
I may have to visit another SC.
Come on Elon, get on this embarrassing problem.
TSLA Pilot
1,644
2,272
United States
Update
While still not a VIN-range listing, Page 9 (of 9) of the SB reads as follows:
Affected Model S and Model X vehicles built between approximately December 15, 2013 and May 15, 2019.
Thus, a July, 2019, production MS Perf Raven should already have the SB parts installed. This suggests that the new "new" half-shafts might have solved the problem, had the SvC installed them. Fixing this shouldn't have been this hard--why isn't there another SB for Ravens yet?!?
So frustrated that they've had the car since Friday, today is Wednesday, and the problem will still be there when I pick the car up.
aerodyne
1,933
1,345
Los Angeles
Correct, should not be a service charge IF the rattle is determined to be a warranty item. The pessimistic side of me says there are 2 ways they can charge me 1) they cannot reproduce the noise 2) they reproduce it but it is not classified as warranty.
The SC in Plano, TX is generally pretty good though.
Repeat after me... vibration...vibration...
Not noise...
vapor trail
196
152
Roseville, CA
Update
As I've posted previously, my SC was preparing to fix the rattle (better not say noise!) on my June, 2019 Raven MS and had preordered the latest half shafts. I'm not entirely clear if the preordered parts are different than what's already on my car, but it implies they have some version of a SB on the issue for Ravens.
I was unfortunately turned away after they decided on a test drive that my issue did not meet their threshold to fix, telling me the rattle is "normal", occuring during a shift in weight under acceleration. Total nonsense.
Reactions: TSLA Pilot
KOL2000
226
178
San Diego
This is MCU emmc nonsense all over again but the mechanical version. My bet is eventually a recall will be forced and they will need to fix this. Another reason to wait before ordering refreshed S - if the new design still has this flaw it will be pretty sad.
Reactions: aerodyne
TSLA Pilot
1,644
2,272
United States
FYI:
Got the car back; not fixed as our July, 2019, MS Perf Raven already has the latest halfshaft part numbers (listed previously). Thus, replacing the halfshafts with the same part numbers was deemed unwise while Tesla engineers are seeking a permanent solution (perhaps a third part number set of even higher quality/capacity halfshafts).
I may look under the car later just to 100% confirm the part numbers as all this was based on the SvC's database search of what part numbers were installed on which cars, according to the Big Tesla Computer in the sky:)
YMMV, but a disappointing outcome.
Reactions: vapor trail
vapor trail
196
152
Roseville, CA
FYI:
I guess we're in similar boats (well, similar cars maybe). At least your SC potentially showed more integrity by admitting there isn't a permanent fix at this point. I've read others report the rattle returning after having half shafts replaced, so that's not a stretch. I just hope that the Tesla brain trust is actually working towards a permanent repair and we're not being given lip service.
