2021 Performance Range Change with Wheel Config
Discussion in 'Model Y: Battery & Charging' started by RoBoRaT, Dec 27, 2020.
  1. Ruffles
    Ruffles Member
    Snohomish WA
    Yes, changing the wheel size is reflected in the estimated range.
  2. Daks
    Daks Member
    Anchorage, AK USA
    We had something in common as it was 4F out this morning when I left - Just need a zero to be at your low temp... Heat is WORKING amazing now. and Regen is too. Tomorrow it should be in the double digits below zero or at least I will be driving to double digits below for the final test. With the wheel change in the computer if I charge up to 90% SOC - I have 268 miles and roughly 150-160 real world miles per Tezlab. I'm running 2021.4.6 software, which has a range increase DISPLAY with this update.
  3. RoBoRaT
    RoBoRaT Zero Farts Given!
    SoCalNorth
    Is that about 313 miles at 100% SoC when your Performance Y was new?
    That's good, considering LR AWD has 326 miles...only 13 miles more.
  4. Ruffles
    Ruffles Member
    Snohomish WA
    I got my PUP last September when the range was 289. It's now showing around 308-313. Honestly, I set it to % and forget about it.
  5. Barrygold
    Barrygold Member
    Midwest
    I have 6,300 mi on my PUP. I put 20s on immediately after purchase which gave me 316 mi rated range. With 3000mi on the odometer I put 19in winter tires on, I’m at 305 mi rated range (3% loss) now which is due to the battery degradation and cold weather.
    FCC376EE-DA4A-4321-8AE0-2EFF93E1FDE7.jpeg 8DFAE291-011C-49C1-84E6-F8F9134EB507.jpeg
  6. RoBoRaT
    SoCalNorth
    This supports the idea that with same (255 mm squared tires) as LR AWD, a Performance Y is at about 316 rated miles (100% SoC) when new.
    I was actually looking for reasons to justify the $11K difference between getting LR vs P.
