Note: This feature currently requires accessing the site using the built-in Safari browser.
FWIW, it can't keep my iPhone 12 Pro topped off if I keep the screen on and run Waze.
Following this thread to see if anyone else has more info. Also curious on the amps that the USB-C ports provide in the front console, if anyone knows.
I have an S21, my 2021 wireless pad does about 10w...the notification on the bottom says 'fast wireless charging.'
So not super fast, but not terrible I guess. I have a 20 minute commute to work and it's usually good for about a 10% charge.
I meant to follow up yesterday, I tried using my Verizon charger from my last phone (Pixel 2XL, no wireless) Verizon USB-C Car Charger with Fast Charge Technology | Verizon and I got over 10% charge in less than 10 minutes. That thing is very fast.That is pretty poop.
Have you tried using the USB-C in the back? Does it say Super Fast Charging?
Can you show your phone positioning? I have a pixel xl 4 - no fast charging and it gets quite hot. Regardless of case no caseI meant to follow up yesterday, I tried using my Verizon charger from my last phone (Pixel 2XL, no wireless) Verizon USB-C Car Charger with Fast Charge Technology | Verizon and I got over 10% charge in less than 10 minutes. That thing is very fast.
I haven't tried using just the C to C cable yet on my S21 since the wireless pad is fine for me, but when I did use just the cable in the inputs it actually didn't charge my Pixel at all. I got the "fast charging" message but no increase of battery. If anything it just maintained it.
So the 12v fast charger outlet might be your best bet if you're looking for a very fast charge.
For the wired charger? I just plug into the outlet in the armrest and coil the cable and phone so it lays on top of each other. The S21 isn't a huge phone so it fits pretty well in the center console there while plugged in.Can you show your phone positioning? I have a pixel xl 4 - no fast charging and it gets quite hot. Regardless of case no case
Sorry total misread was looking for wirelessFor the wired charger? I just plug into the outlet in the armrest and coil the cable and phone so it lays on top of each other. The S21 isn't a huge phone so it fits pretty well in the center console there while plugged in.
I just lay it on the pad. I have a cheap Spigen case on my S21 that doesn't interfere with charging speeds at all, other than it takes 2 seconds to start charging vs the immediate charging when it was 'naked' with no case on it.Sorry total misread was looking for wireless
It's so terrible. Barely charges and undoubtedly the heat ruins your phone. Has anyone taken this apart?! Upgraded? Tesla service says it's normal and fine (went for several other different things)This is one of the things I am most disappointed about on my '21 M3P. The charging is pretty slow, phone gets hot, and it doesn't take much at all for it to get out of place and stop charging. I've found that keeping it scooted to the center of the pad helps a tiny bit.
I have the same exact problem with my iPhone 12 Pro MaxFWIW, it can't keep my iPhone 12 Pro topped off if I keep the screen on and run Waze.
