Already doing accordingly, exactly I will do. EnjoyingThese alignment issues will not have any noticeable impact on range. You have a new car and its incredibly fast, don't compare consumption until you drive it like your previous one. Get the panel gaps checked by your SeC, don’t take the within spec bull, especially not the charge port and top right trunk alignment, that looks close to scraping and while they are at it they can also get it centered. The right door should be an easy fix for them. Now stop obsessing and start enjoying.
My exterior alignments/gaps are good, even the typically bad ones on the rear doors. I made several visits to a new store and let my expectations be known MONTHS prior to delivery.These alignment issues will not have any noticeable impact on range. You have a new car and its incredibly fast, don't compare consumption until you drive it like your previous one. Get the panel gaps checked by your SeC, don’t take the within spec bull, especially not the charge port and top right trunk alignment, that looks close to scraping and while they are at it they can also get it centered. The right door should be an easy fix for them. Now stop obsessing and start enjoying.
By the way it is a pic of the charge port right? I think I read here on the forum someone else had the same issue and think they had to replace it.
Correct, you could have a car the size of the sun have it lower than your car. A Tesla semi and a Bugatti Veyron have the same drag coefficient.Just because the refresh MS has a much ballyhooed low drag coefficient, does NOT mean lower aero drag than say a M3. It is a bigger car with a larger reference area.
My repair and alignment was WELL made last week, at least it's parallel now, so the neighbors do not wrinkle their nose so high longerMy exterior alignments/gaps are good, even the typically bad ones on the rear doors. I made several visits to a new store and let my expectations be known MONTHS prior to delivery.
However, I was not expecting them to fix by taking a steel hammer to the door hinges! I did some touch up, and it looks better now.
Most everything else wrong I had to fix myself.
Just glad I dont have the dreaded vibration...yet
Charge port is fine, just looks strange from angle operation, but works well, no problemBy the way it is a pic of the charge port right? I think I read here on the forum someone else had the same issue and think they had to replace it.
Seals are probably misaligned, or not properly installed. Open the doors fully, see if the seals are loose or misplaced.Now after an while, I noticed: With this new plaid, registration 30.12, the right front door and the left rear seat door are so poorly insulated and sealed that there is a real flow of cold air. I have concerns about whether I should have cavity preservation done, because the air inlet is the same as moisture, rust or rust is that exaggerated....
Has somebody an idea, to solve this crazy issue?
((, now I started to take a thick blanket with me to keep out the ddraught))
Junk 🤣Seals are probably misaligned, or not properly installed. Open the doors fully, see if the seals are loose or misplaced.
Also, there is an insulating pad just forward of the front doors that may be misplaced. Open Frunk and look down opening near hinges. The black pad should be pushed aft in front of the door hinge, blocking airflow.
Junk 🤣
True, just some parts are cheap/junk, and some systems not well executed. Then there are things like the “normal” vibrating DUs and shafts. @WilliamG also takes issue with the hinges! 🤣Many parts are good quality, not junk. Poorly placed or broken during installation, yes.😉
Gut gemacht. Top!My repair and alignment was WELL made last week, at least it's parallel now, so the neighbors do not wrinkle their nose so high longer_
Saw a MX at Van Nuys SvC last fall.
Covered with small pieces of green painters tape.
On every one, it was written, "Within Spec"
