what u mean ?It's fine. It shut down with 4kwh of anti brick buffer.
This is a perfect learning point for any new owners out there. Never leave your car unplugged with a low state of charge, especially at 0 miles or when its cold out. Plug it in immediately and charge.Well, let me explain.
I was on my way back from Orlando, and the mile marker was zero and there were 10 miles to go, to get home. I kept driving until I got to my house, I drove the car into the garage, and I didn't put the charging cable right away, after 2 hours when I went to put the cable in, the car was completely dead. When I put the cable, nothing happened, the wall charger connector light remained blue because there was no communication with the car.
There's a small amount of reserve energy left in the high voltage pack that normally will not be discharged, under any condition. This prevents you from damaging your high voltage pack by running it to zero, like you did. That said, try to never do this again.what u mean ?
You right !This is a perfect learning point for any new owners out there. Never leave your car unplugged with a low state of charge, especially at 0 miles or when its cold out. Plug it in immediately and charge.
Got it !There's a small amount of reserve energy left in the high voltage pack that normally will not be discharged, under any condition. This prevents you from damaging your high voltage pack by running it to zero, like you did. That said, try to never do this again.
What that means ?
I did and its horrible, doesnt explain the details.....actually the new model x 2022 there is no much information at the manual and online.... I got lucky because @Tz00 and another two guys here....they gave me a lot of useful tips.... but the car its fine now !! thx everyone !I would suggest reading the owner's manual.
Yeah I will....thxWelcome to Tesla ownership lol! Basically, just keep your car plugged in if possible. If not, keep the charge high enough so it doesn't drain.
Yeah I will....thx
You can store it at 90%, no problem. But, yes, the closer to the middle the better.And don't store it more than 70% for long periods. Charge it right before you leave to the higher SOC if you need the range. Ideally you'd store it around 50% and then charge to what you need so it finishes charging to that level when you need to leave.
Yes, the higher you store it above half, the faster it will degrade. Will it degrade suddenly overnight storing it at 90%? No but it'll be the difference between 20 and 50 miles of degradation after 8 years if you always store it at 90%.
question about always leaving it on the charge: should it be left at a low amperage (lets say 20A) or the highest amperage that the car can take (48A in case of my MS)?Yes, the higher you store it above half, the faster it will degrade. Will it degrade suddenly overnight storing it at 90%? No but it'll be the difference between 20 and 50 miles of degradation after 8 years if you always store it at 90%.
So let me get this straight, you have a brand new 2022 X worth $120K+, you drove 10 miles past 0% SOC of charge, you got home and DIDN’T plug it in?Well, let me explain.
That is abuse. I would not treat a $140k car like that.Well, let me explain.
