21” Grey Turbine Upgrade Parts List
When upgrading from the 19” to 21” Grey Turbines you may need some parts if buying a used set.
This thread is about sharing the part# and things to consider. Here is what I found so far:
WHEEL CENTER CAP - GREY (6005879-01-A) 4 x $5.00 = $20.00
LUG NUT COVER - BLACK (1023838-00-A) 20 x $0.39 = $7.80
TPMS, SENSOR, 433 MHz SILVER VALVE STEM (1034602-00-C) 1 x $70.00 = 70.00
Are the lug nuts on the 19” the same for 21”?
Would anyone like to add the gen2 TPMS pn#?
Are the easier to find online model3 grey caps the same pn# and size?
Just to kind of piggyback on this post. I do plan on upgrading to 21" wheels and purchasing used, but some offer gen 2 tpms and have read that it doesn't play well if your car is fitted for gen 1.
How do you check the gen of your current tpms?
(coming from a 2014 p85)
If you see tire psi on the cluster left side you have gen2. SC upgraded my 2013 complementary.
Update: the lugs on 19” do fit the gray 21”. However the lug caps DO NOT FIT those lugs. You need to get new lugs or maybe they will good will them for you. SC said i had the old acron kind that get stripped eventually so they put newer style on.
Love tesla service!
Hey man, any suggestions where one might procure said parts at these prices? Like the center caps for example.
I will be receiving a set of staggered 21 inch turbines tomorrow and want to get all the other parts ready before installing.
Thanks .
