21" best size TIRES!!! M5 Front 265/35/20 rear 295/30/20; Audi S7 265/35/20.
Discussion in 'Model S: Driving Dynamics' started by miamimd, Mar 15, 2013.
  1. miamimd
    miamimd Member
    Miami
    Question for all the experts in this Forum. What's the best size of tires for the 21" wheels. For me the 245/35/21 is not wide enough for all the power on the P85.
    What's your advice?
  2. tdiggity
    tdiggity Member
    Bay Area, CA
    #2 tdiggity, Mar 15, 2013
    265/35/21 tires are $400+ a piece. and you only get 5 to choose from (on tirerack.com). Very limited. You probably won't be able to run 265's in the front.
    You could try just changing out the rear tires.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Wider tires won't increase the size of your contact patch. It will help with cornering, but not acceleration.
  4. miamimd
    miamimd Member
    Miami
    The Michelin Pilot Sport PS2 are $533 a piece. What about tread-wear between the 265s and the 245s. Why I can not run 265s in the front?
    Thanks for your input
  5. tdiggity
    tdiggity Member
    Bay Area, CA
    You can't run 265 up front because there most likely isn't room.
  6. araxara
    araxara S-P85#3,218 X-LR M3AWD
    Tucson, AZ
    Someone mentioned in another thread that they had put on 255s in the front and had rubbing when turning the steering wheel turn-to-turn.
  7. mnx
    mnx 2013 P85
    Ancaster, Canada
    Me. :) It's pretty infrequent, I wouldn't hesitate to put 255's in the front again, but I wouldn't be willing to try out 265's in front.
