21" Rim or 22" Rim
Discussion in 'Hong Kong' started by danny9808, Jun 30, 2015.
Tags:
  1. danny9808
    danny9808 Member
    Hong Kong
    Are there any members here have experience to change the rims to 21" or 22"? I have asked a tyre shop today. They say that only 21" rim can be changed to Model S. I read some articles that some onwers changed to 22" rims. Can anybody share his experience?
  2. deku
    deku Member
    Hong Kong
    A lot of tune shop in US fit 22" for Tesla. I know Causewaybay advan shop have a set of 2nd hand Vossen CVT 22 inch fits tesla model S. But personally I won't go for 22". Because its degrading the performance too much. too big the wheels, higher mass, higher unsprung mass, slower, lower acceleration, use more energy, noisy, bumpy, faster wear, tire easy to blow by sidewall damage run over pot hole or curb rash, Only pros is cosmetics and less tire wall flex (reduce heat during aggressive corning)
  3. danny9808
    danny9808 Member
    Hong Kong
    What size of tires did you choose for 21" rim?
  4. deku
    deku Member
    Hong Kong
    I ordered 19" stock wheel. I am struggling with either just stick to 19" and change tyre to Michelin PSS or up to 20" wheels for a better look. The stock tyre is All season which is not suitable in Hong Kong, I will sell them once I get the car. Probably 245/40/R20 Front, 275/35/R20 Rear with any max / ultra performance summer tyre. Performance and comfort probably 19" is the best.
  5. Tony Lin
    Tony Lin Member
    Hong Kong
    I run a forged 21" with 245 front and 285 rear, personally, I love it! My wheels are lighter than factory 19". I think 22 is too big for HK. You can achieve close to 22 look with 21 if you slam the car. Plus, 22 is heavy, unless forge! If you have P85D, I think it can handle 22.
  6. deku
    deku Member
    Hong Kong
    Have you guys ever heard Tesla service say about void warranty on suspension, drive unit and brakes if we change to wheel size not the same as OE. This is the answer I got some time ago. After some six months later another Tesla guy told me that only if damage is caused by the aftermarket wheel will void warranty. But they did mention they will refuse to service on cars that they need to touch the aftermarket wheels, like changing brake pads, etc. You will need to change back to stock wheel before they will work on it. The biggest struggle for me to upgrade is that, I need to keep that four wheels somewhere in case I need service. I probably need to rent a mini storage to hold on to them. I live in an apartment with non-fixed parking rental car park means I cannot put the wheels at the back of the parking And no way I would put four wheels in my home either.
  7. Dvc
    Dvc Member
    HK
    22" is ok for MS but my opinion is only good for non-D model in HK.
    you may know that Tesla is deliveiring a squared 245/21 setup instead of staggered 265 for P85D if u took the 21" option........... Properly they finally realized that is downright dangerous to run staggered setup in AWD. So if u have a D model, suggest u to keep the same size or similar rolling radius for the front and rear.
    After u found the right circumference and fitments to suit for AWD, u would realise that not much choices on tyre if u decided to go for 22" and I don't think u would consider to put all seasons rubbers in HK.
  8. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
  9. danny9808
    danny9808 Member
    Hong Kong
    Hi Tony,
    What model do you have? is there any problem to use 285 tyre at rear from your Model S?
  10. Tony Lin
    Tony Lin Member
    Hong Kong
    #10 Tony Lin, Jun 30, 2015
    danny, i have 85. no issue with 285!
    - - - Updated - - -
    Not much choices on tires, and pricey!.
    Mich PSS is back ordered, takes about 2 month to order.
    I find conti is quieter!
  11. jsu626
    jsu626 Member
    Los Angeles
    I have a P85D, and recently installed DPE ES5 22x9.5 (255x35x22) front 22x10.5 (295x25x22) rear. I have also lowered it 0.5" with airmatic lowering links.
    The front rubs in reverse when when steering is in full turn and car set at lowest setting, the ride & performance is about the same. But otherwise, love the look and no other complaints
  12. lolachampcar
    lolachampcar Active Member
    WPB Florida
  13. Tony Lin
    Tony Lin Member
    Hong Kong
    21" Rim or 22" Rim
    Lower to 1 finger gap, no rubbing!
  14. telegogo
    telegogo Member
    Hong Kong
    ADV 1? How much for it?
  15. Tony Lin
    Tony Lin Member
    Hong Kong
    No its Pur
  16. telegogo
    telegogo Member
    Hong Kong
    21"?
    It looks good. How much does it cost?
  17. Tony Lin
    Tony Lin Member
    Hong Kong
    Yah 21". About 6 large, freight to Asia $$
  18. deku
    deku Member
    Hong Kong
  19. Tony Lin
    Tony Lin Member
    Hong Kong
    That's very tempting, but blew my money on these wheels [emoji23]. Gotta wait! Wonder if this would void warranty.
  20. joywalker
    joywalker Member
    Hong Kong
    I'm making constant effort to remind myself not to scratch the big wheels at turns.
    Perhaps will take a long time to get used to, until then, will feel the pressure always.
